tail/side light goes out when headlight on
skikman
PostPosted: 18:57 - 27 Apr 2013    Post subject: tail/side light goes out when headlight on Reply with quote
putting a wee suzuki gs 125 together and cant get the lights to work properly.all lights work its only when i put the headlight on it cuts out the tail and side/dash lights.been switching wires around but cant figure it out.any ideas?
Copycat73
PostPosted: 10:49 - 28 Apr 2013    Post subject: Reply with quote
likely a bad earth wire.
caveat emptor
cimbian
PostPosted: 10:52 - 28 Apr 2013    Post subject: Reply with quote
Dodgy switch or poor earth.
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
Copycat73
PostPosted: 10:54 - 28 Apr 2013    Post subject: Reply with quote
ps. remove headlight bulb and try side light then.
have a good look at the stop /tail light.. if you got a good working spare put that in.
caveat emptor
skikman
PostPosted: 12:40 - 29 Apr 2013    Post subject: switch Reply with quote
ended up being corrosion at the switch.bit off a clean and wd40 and it works ok now.as always i had been through everything else and had everything apart before i got to the switch.why is it always the last thing you look at?anyway im just glad its sorted.thanks again folks.
raesewell
PostPosted: 12:44 - 29 Apr 2013    Post subject: Reply with quote
it'a always the last thing you look at because once you have found it you stop looking Razz
The last post was made 13 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 46.74 Kb
