| Lord Percy |
 Lord Percy World Chat Champion
 Posted: 09:56 - 29 Apr 2013 Post subject: No spark, everything else works 100% fine |
Why is it that I can arrive home on a perfectly working bike and then in the morning it's just dead?!?!
There's no spark coming from the HT leads. Everything else seems to be 100% ok - lights, indicators, starter motor (lots of power but obviously will drain eventually), etc are all totally fine as far as I can tell.
I've checked the leads for a spark and there's nothing. So what the hell has happened over night? There are two leads and both are dead. What could this mean? What should I check??!?!?
I've taken off the seat and tank and can't see anything damaged or unplugged. If a component is broken, which one would it be? Is there are way I can check if I don't have a mulitmeter.....?
I suspect something like the kickstand cut-off but that seems fine too - when the stand is up, the light on the dash turns off, so I guess that circuit is fine. I can't think what else to check. It's just odd that it's suddenly completely died over night. Not a single chug of life in it this morning, the engine just turns and turns.
It's a Honda CMX 250.
Thanks  |
| Lord Percy |
 Posted: 10:26 - 29 Apr 2013 Post subject: |
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 10:32 - 29 Apr 2013 Post subject: |
Not the only one you know
Cue thinking of me breaking down in the desert of Nevada while in Las Vegas doing the Valley of Fire ride out! ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| Teflon-Mike |
 Posted: 10:34 - 29 Apr 2013 Post subject: |
CMX uses the same self excited ignition as the other benley engines I believe.
The motor needs to spin pretty well to get enough amps out of it for sparks. Have had bikes show all signs of life but a spark, and its been that they are just not turning over fast enough.
That's first check.
Second. you say you have checked the HT leads for spark. Have you pulled the plugs? Shitty plugs need more electric to get past insulating soot and crap on the electrodes. Worn plugs will have lost the edge to their electrodes and again, makes sparking harder.
Ignition system is otherwise pretty simple, and if its working when warm, unlikely to be the trigger inductor; CDi or coil. BUT its a 'make to kill' ignition; turned 'off' by making a circuit through the ignition, kill or side-stand switch.
So I'd be tracing the, I think it's black/white wire swuibbing switches with WD40 and looking for a short from fretted or melted wire ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Lord Percy |
 Posted: 10:37 - 29 Apr 2013 Post subject: |
Cheers for the info BUT, check the second post in thread
| Islander |
 Islander World Chat Champion
 Posted: 11:10 - 29 Apr 2013 Post subject: |
D'oh.  |
| Fizzer Thou |
 Posted: 12:09 - 29 Apr 2013 Post subject: |
Yup - easily done  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| Lord Percy |
 Posted: 12:16 - 29 Apr 2013 Post subject: |
I just find it hilarious that I went to such lengths before discovering how stupid I'd been. Even called work and missed my shift!!!  |
| Fizzer Thou |
 Posted: 12:23 - 29 Apr 2013 Post subject: |
There was a BCF member in my workshop the other year learning how to do a simple oil and filter change to his Triumph.When it came time to start the engine it just did not want to know.What made things more difficult to diagnose was that there were handlebar/handguard muffs fitted and so we could not see that the kill switch was operated.Took a good few minutes of head scratching before that was realised  ____________________ Just talk bikes.What else is there?
| Islander |
 Posted: 12:26 - 29 Apr 2013 Post subject: |
I think everyone who's ever owned a bike with a kill switch has done this at least once.  |
| MatteyA |
 MatteyA Derestricted Danger
The last post was made 13 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
