GPX 600 Caliper help
R1stu
Shrek!
PostPosted: 08:47 - 29 Apr 2013    Post subject: GPX 600 Caliper help Reply with quote
Ok Ive spent the weekend sorting bike, I had to replace fork oil, put in new bulb, wire in a 12v socket and fit a scotoiler.
All of this went well, but now I cant sort the front caliper. upon trying to get the right one open enough to fit over the disc, the pad popped out.
I cant get the pad back in and cant see a way of taking the caliper apart to replace the pads. also trying to get the pistons all the way down is proving to be an issue.
Any one with one of these bikes now how to sort the calipers?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Fizzer Thou
PostPosted: 10:13 - 29 Apr 2013    Post subject: Reply with quote
I worked on my brothers Kwack GTR1000 a few years ago and he had a problem with one of the severely worn pads falling out of the caliper mounting.I seem to remember that the pad locates onto a pin that the pad slides on.When the pad is new it locates much better onto said pin but all too easily can become easily misplaced when worn.
A photo of your caliper would help to sort your problem.Is it a twin piston floating caliper?
Always have a 'Plan B'
R1stu
Shrek!
PostPosted: 10:28 - 29 Apr 2013    Post subject: Reply with quote
this is what it looks like, and B is the one thats fallen out.
https://img.auctiva.com/imgdata/1/4/2/7/1/5/7/webimg/601774745_tp.jpg
https://www.motorcycle-road-and-race.co.uk/images/FA129.jpg
Islander
PostPosted: 10:36 - 29 Apr 2013    Post subject: Reply with quote
That's the same caliper as my OH's Zephyr. The lugs on the smaller pad locate behind the mounting plate lugs with the clip on springs. It's probable that the mounting plate isn't sliding freely and isn't moving forward enough to hold the pad in place. If this is the case then the hole that the longer of the two boots fits into will have corrosion build up inside it stopping the caliper moving freely on the pins. Remove the boot, and clean it out thoroughly before reassembling. I've just rebuilt three of these. Mr. Green
That caliper is in dire need of a good servicing BTW. Wink
Fizzer Thou
PostPosted: 10:40 - 29 Apr 2013    Post subject: Reply with quote
That is the same pad that fell out of my brother's caliper.You can see how it locates onto a shoulder of the caliper bracket.
From what I remember the mounting bracket needs to be withdrawn from the caliper body on the floating pins.Push the fixed pad against the pistons and that should give you the clearance to disengage it.Once the two are seperated then slide the fixed pad off the fore and aft mounting pins.
When my brother rang me and said that the braking on his GTR was really not working very well and could I have a look for him,one quick look at the caliper told me that the piston inserts rubbing against the disc does not make for very good friction Rolling Eyes
Islander
PostPosted: 10:46 - 29 Apr 2013    Post subject: Reply with quote
For the avoidance of doubt see the attached pics:
R1stu
Shrek!
PostPosted: 11:05 - 29 Apr 2013    Post subject: Reply with quote
Thats not my caliper, I googled it Cool I relise where the pad clips into but with the piston up they don't sit under. I will get some pics later when home if go home and stick up
How do I get the boots and pins out? I pulled the rubber and it snapped off and there is a rod behind there but cant see a way of removing it.
Fizzer Thou
PostPosted: 11:18 - 29 Apr 2013    Post subject: Reply with quote
If you have a look at this fiche (I know that it is not your model of Kwack but I could not find the relevant one-but the caliper/bracket is the same)
https://www.cmsnl.com/kawasaki-1989-b2-zx1000_model12743/partslist/G5.html#results
you will see that the caliper mounting bracket locates into the caliper body.So you need to push the fixed pad against the caliper pistons so that you can part the bracket from the caliper.
Islander
PostPosted: 11:20 - 29 Apr 2013    Post subject: Reply with quote
It won't sit behind the lugs because the caliper isn't free to move on the mounting plate pins. The mounting plate just pulls out of the caliper body - it'll be jammed by the corrosion and may need some gentle - and I do mean gentle - persuasion to come out.
Wemoto sell the rubber boots for these. Replace them both and lubricate with grease suitable for rubber. Then check the other calipers - I'll bet they have the same problem. Thumbs Up
R1stu
Shrek!
PostPosted: 14:47 - 29 Apr 2013    Post subject: Reply with quote
Hopefull can get pad back in tonight or tomorrow, otherwise slow ride into work wed. Lucky I have a bike garage below my office.
Casper
PostPosted: 15:29 - 29 Apr 2013    Post subject: Reply with quote
Almost the same as mine but I have one piston. Parts 92081 in that ^^ link help hold the pad in place. You still got yours in place?
R1stu
Shrek!
PostPosted: 15:33 - 29 Apr 2013    Post subject: Reply with quote
Yep in place. Will take pics when get home. may get my G Clamps and use them to get both pistons flush.
Casper
PostPosted: 15:43 - 29 Apr 2013    Post subject: Reply with quote
When I renew pads I push the pistons out first almost to the point where they fall out. Give a wee wipe and lube and push back with a plumbers wrench
https://us.123rf.com/400wm/400/400/ajt/ajt0711/ajt071100035/2142971-adjustable-pipe-wrench-isolated-on-white-background.jpg
R1stu
Shrek!
PostPosted: 18:19 - 29 Apr 2013    Post subject: Reply with quote
here some pics my caliper.
https://i145.photobucket.com/albums/r232/stuartkeith/100_4048_zpsc4c4eb7b.jpg
https://i145.photobucket.com/albums/r232/stuartkeith/100_4050_zps3327cc21.jpg
https://i145.photobucket.com/albums/r232/stuartkeith/100_4051_zpsaa9948de.jpg
https://i145.photobucket.com/albums/r232/stuartkeith/100_4052_zpsf5227d66.jpg
https://i145.photobucket.com/albums/r232/stuartkeith/100_4053_zps917ab8a8.jpg
Casper
PostPosted: 19:19 - 29 Apr 2013    Post subject: Reply with quote
The pistons are out to far so you cant hook the other pad in. Pump them out another cm and clean them a bit. Give a little lube and push back in then hook the pad back in. You need to push down first as it sits on a spring. Well I say spring its that silver bit of metal you see at the bottom.
Casper
PostPosted: 19:20 - 29 Apr 2013    Post subject: Reply with quote
BTW. Pull out the hanger and lube up under the rubbers as they dry out quite quick. If sticking they wont help trying to get the pads in.
R1stu
Shrek!
PostPosted: 19:44 - 29 Apr 2013    Post subject: Reply with quote
Tried pulling out wont budge, so bit wd in there and remove?.
Islander
PostPosted: 20:15 - 29 Apr 2013    Post subject: Reply with quote
I told you the reason the mounting bracket won't move - there's corrosion build up in the side that had the long rubber boot through it. You need to gently tap the bracket down as far as it will go, remove the other pad, then tap the bracket up until it comes out. Remove the remains of the boot and carefully use a round file or similar to remove the corrosion - don't remove any metal!.
Then install a new boot, lube it with a suitable rubber friendly grease and put it back together.
To be honest, I'd be looking at removing those pistons and replacing the main and dust seals. If the pistons are badly pitted then you may have to replace them. Wemoto do the rebuild kits and stainless pistons if they're needed - unfortunately they ain't cheap.
You'll need to check your other calipers because I'll guarantee they're in the same state.
Casper
PostPosted: 22:38 - 29 Apr 2013    Post subject: Reply with quote
It does look and sound like strip down time. Apart from sticky callipers you run the risk of warping the disks and falling on your all in front of sexy chicks.
R1stu
Shrek!
PostPosted: 09:26 - 30 Apr 2013    Post subject: Reply with quote
ill bodge it together for this week. am off all next week so will do a full rebuild then. brakes have been working well since had the bike, only took the forks off to replace oil as they were bottoming out.
R1stu
Shrek!
PostPosted: 14:05 - 01 May 2013    Post subject: Reply with quote
All sorted now. Dremeled with a light brush and then sprayed with lots of brake cleaner and a toothbrush. Wiped some fluid around and then un done the banjo and used a g-clamp to compress the pistons.
The bracket came of nice and easy, no corrosion, but i wiped it down and greased, Topped the fluid and bleed, and the brakes are far better then before, and the added advantage of the forks no longer bottom out!
Thumbs Up Mr. Green
mentalboy
PostPosted: 17:18 - 01 May 2013    Post subject: Reply with quote
You'd best hope that by pushing those scabby pistons back into the caliper you haven't wrecked the oil seals! (Even if you managed to dremel them all the way round the pits may give grief to your seals)
Make mine a Corona.
R1stu
Shrek!
PostPosted: 18:23 - 01 May 2013    Post subject: Reply with quote
Ill keep and eye on them for the next few days. but the brakes are far better than before!
Casper
PostPosted: 18:41 - 01 May 2013    Post subject: Reply with quote
Lol. That was my cowboy fix on my brakes a couple of years ago. Seals are still fine.
mentalboy
PostPosted: 19:40 - 01 May 2013    Post subject: Reply with quote
I'm all for making do with what you've got ( take a gander at the thread on my zed's journey back to road life to see some of my bodges!)
BUT I know the consequences that can result from my bodges whilst some people out there seem genuinely surprised when they bodge something and it backfires on them - jivebunny springs to mind Rolling Eyes - I'm not saying the OP doesn't know but sometimes we do these things without further thought and the braking system is one of those areas that I personally like to function at it's best.
Make mine a Corona.
The last post was made 12 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 135.16 Kb
