water pump failure? Noise?
mysterious_rider
PostPosted: 19:01 - 28 Apr 2013    Post subject: water pump failure? Noise? Reply with quote
Hello chaps, I think I've narrowed down the squeaking on the zzr to the water pump, however, is it normal for an intermittent squeak before they let go? It does it LOUD when it's cold, then almost nothing when It's warm.
Is it worth taking it apart? If I take the reservoir cap off water is still being jetted in. However on idle I could quite happily leave the lid off and no water would spray out. Only when I rev. Surely they're supposed to be under more pressure than this?
What's there to make a noise inside it anyway? Pretty sure it's not belt driven? Laughing
KAWASAKIIIII
mysterious_rider
PostPosted: 12:10 - 29 Apr 2013    Post subject: Reply with quote
Right, took the cover off and the impellor behind (buried in the engine) is what is causing the squeak. I CANNOT remove it! Impossible!!! I've tried levering it out, molegrips, etc, The only thing left is to cut it out.
Any ideas?
KAWASAKIIIII
mysterious_rider
PostPosted: 15:24 - 29 Apr 2013    Post subject: Reply with quote
It's supposed to be a sealed unit? Realised the whole thing does come out, bodged to fuckery and took the damaged bearing down the bearing shop, £9 lighter and a fresh unit! Note to self, they run two bearings not one. Embarassed Replaced one, but the second one still turns freely/not notchy so will re-use. On down side having to go buy a new water pump seal, bastid has swolen since it's been out of the bike.#
cheers mate! Runs smooth now at least. Smile
KAWASAKIIIII
The last post was made 13 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 53.89 Kb
