SV 1000 Hot starting problems
bandit_engineer
PostPosted: 13:56 - 02 Feb 2013    Post subject: SV 1000 Hot starting problems Reply with quote
Afternoon All,
Does anyone know what can cause "hot" starting problems on an SV 1000. Confused
Bike will start fine from cold, however once up to temperature and stopped. Petrol station etc. will not start again. Will crank until battery is flat however will not fire. Evil or Very Mad
Checked spark plugs. Oil is up to level.
Is there a sensor that could have gone and if so which one?
Thanks
John
Previous: 2002 Speedfight 50, 2000 RS125, 2002 RS125, 1997 Bandit 600N, 2003 SV1000S
Current: 2007 GSXR 750 (Isle of Man)
serlant
PostPosted: 20:41 - 02 Feb 2013    Post subject: Reply with quote
Can be caused by tight exhaust valves. have you checked the clearances recently?
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
bandit_engineer
PostPosted: 20:42 - 29 Apr 2013    Post subject: Reply with quote
Going on from this.
Valve clearences have been checked and were just below the minimum. This has been sorted and all are now within spec Smile .
However it will still happen on occasions where she will crank and not fire. Sad .
Tried dealer mode and no codes.
Any guidence appreciated Karma
John
Ariel Badger
PostPosted: 20:54 - 29 Apr 2013    Post subject: Reply with quote
Is the bike carbed?
bandit_engineer
PostPosted: 20:56 - 29 Apr 2013    Post subject: Reply with quote
Ariel,
No, bike is fuel injected.
John
bandit_engineer
PostPosted: 21:05 - 29 Apr 2013    Post subject: Reply with quote
i have tried that technique and she will start and run. Once started the bike will run fine.
John
bandit_engineer
PostPosted: 21:18 - 29 Apr 2013    Post subject: Reply with quote
yes it will.
it will also start if you crank it long enough to get the FI light to flash and then ignition off and on.
Will have a look at the fuel filter first as this is easier Smile .
Thanks
John
The last post was made 13 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 49.87 Kb
