recommend me a torque wrench please
DottyDuck
PostPosted: 01:57 - 30 Apr 2013    Post subject: recommend me a torque wrench please Reply with quote
Hello everyone... could do with a torque wrench...obviously cheaper. The better! But would rather pay a bit more... if it means better quality... would be good if it could be from a shop so i can collect it lol.. but will order of the internet if i have too...(just means i just have too wait!) Lol
Thanks everyone Smile
CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14 Very Happy
Old Bike: Zontes Panther 125cc - wrote off Sad Current Bike: Kawasaki ZR7 Very Happy Wub
trevor saxe-coburg-gotha
PostPosted: 02:06 - 30 Apr 2013    Post subject: Reply with quote
I am guessing you want a low value one - like, say, 5-25Nm? Probably would cover most stuff on a 125 - hmmm maybe not the rear sprocket though, sometimes those are higher than 25 iirc. Someone will know much better than me. But here's the thing - I've never used mine. I just nip stuff up a bit - remembering that it's very easy to overdo it, especially when going into alloy (sump bolt, etc). Swing arm, not so much - but even then, go easy cos you can put too much pressure on spindle / bearings innit. Anyway, think I paid about £30-£40. Wish I hadn't bothered.
Codemonkey
PostPosted: 07:12 - 30 Apr 2013    Post subject: Reply with quote
I've got a Halfords 8-60Nm one like this:
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_178843_langId_-1_categoryId_165469
Comes with a calibration certificate and has covered pretty much everything I've done so far except the rear axel nut.
Test Passed 10/05/2011 Current bike: XJ6-N
PostPosted: 07:56 - 30 Apr 2013    Post subject: Reply with quote
For what purpose?
I don't trust the clicky ones they come over here, they steal our torques.
For one thing, manuals tend to be works of fiction. They're not called Haynes Books of Lies for nothing. Even if they're correct, they give ideal numbers for what's often an unknown condition of fastener. Dry? Oiled? Threadlocked? Copper greased? Covered in crud?
Your bike may not agree, particularly if it's (just for example) off of a Chinese sweatshop production line that gets its raw material from Wun Hung Lo's House of Approximately Metallic Substances.
It's cold comfort that it's not your fault if you strip out your sump plug before the clicky wrench has clicked. You've still got a stripped sump, and nobody will care.
Personally, I always go by the size of the fastener and by feel. I very occasionally bust out an old deflecting beam style wrench:
https://www.parktool.com/uploads/images/blog/repair_help/tw5.jpg
But only as an aid to mechanical sympathy, not as a replacement.
Not what you wanted to hear, I know.
CarlosCBR
PostPosted: 09:08 - 30 Apr 2013    Post subject: Reply with quote
I've got one of these
https://www.ebay.co.uk/itm/Draper-34570-3-8-Square-Drive-10-80-Nm-or-88-5-708-In-lb-Ratchet-Torque-Wrench-/171005497137?pt=UK_Hand_Tools_Equipment&hash=item27d0b8cf31
Been fantastic for three years and i havent had a wheel fall off yet..... touch wood!
map
Mr Calendar
PostPosted: 09:11 - 30 Apr 2013    Post subject: Reply with quote
Rogerborg wrote:
For what purpose?...
This is a good question. I use two, one for the smaller stuff and a bigger one for the larger stuff like wheel nits.
Rogerborg wrote:
...I don't trust the clicky ones they come over here, they steal our torques....
Horses for courses. Best if you can to try before you buy and place into vice and test that 'click'. Some are non-existent.
Rogerborg wrote:
...Even if they're correct, they give ideal numbers for what's often an unknown condition of fastener. Dry? Oiled? Threadlocked? Copper greased? Covered in crud?...
A torque wrench should only be used to check the tightening. I'll repeat that for clarification, only use a torque wrench to check how tight a nut/bolt us. As this is the case then you have a chance to inspect and clean, lube, replace as required. In my experience copper grease or threadlock don't change torque settings.
On topic as it'll be something you use very occasionally no point in breaking the bank. If you can get any deals on the Halfords Professional stuff then do it. This as lifetime guarantee. However, keep receipt in a folder in a safe place as they can be right jobsworth buggers without one.
I've found for small stuff my cheap and cheerful Draper has been enough.
cimbian
PostPosted: 09:22 - 30 Apr 2013    Post subject: Reply with quote
Experience ain't the same as knowledge. Rolling Eyes
30 to 40 percent of torque is associated with friction in the threads, therefore anything in there will alter the torque, with some having quite considerable effect.
Up to 50 percent is associated with friction under the fastener's head, again, any crud or lubricant is likely to alter things considerably.
As little as 10 percent may be involved in the actual clamping of the actual parts.
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
The last post was made 13 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 57.87 Kb
