Replacing the clutch cover
_Troy_
PostPosted: 21:06 - 30 Apr 2013    Post subject: Replacing the clutch cover Reply with quote
Like many old SV's, mine leaks a little oil through the clutch cover. I've finally got myself a replacement, so will attempt to fit it tomorrow.
I changed the oil and filter less than 1000 miles ago, so I'm reluctant to do it all again so soon. Do you think it would be ok to simply place a catch tray under the bike, remove the cover, replace, and top up? With the bike on its side stand am I likely to lose that much oil?
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
Bezzer
PostPosted: 21:17 - 30 Apr 2013    Post subject: Reply with quote
You can usually get away without losing much/any oil if you run the bike onto a plank then put it onto the sidestand so it's leaning over further. You don't lose any on a Bandit with a 30mm plank
_Troy_
PostPosted: 21:21 - 30 Apr 2013    Post subject: Reply with quote
The SV has quite a lean as it is, so I could maybe get away with leaning it with a slight camber in the road?
Oh another question. I replaced the clutch cover seal when I did my oil change. Does anyone know if it'll be fine to reuse? I don't see any reason why it wouldn't.
ian505050
PostPosted: 21:34 - 30 Apr 2013    Post subject: Reply with quote
You could just drain the oil into a clean container and put it back in the bike when you replace the clutch cover?
Its simpley undoing the sump bolt, putting it back in and refilling the oil???
You make it sound difficult
andym
PostPosted: 21:43 - 30 Apr 2013    Post subject: Reply with quote
I've done a divvy clutch, gpz clutch and zxr clutch and never once drained the oil... mind you I'm never going near a sump bolt again after my last effort
_Troy_
PostPosted: 22:09 - 30 Apr 2013    Post subject: Reply with quote
Sump bolts are notorious for being a pain in the arse, and I don't trust the container to be clean enough to re-use the oil. I'll give it a go with some mega lean. How hard can it be?
The last post was made 12 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 47.33 Kb
