Muffling
VPulse
PostPosted: 03:47 - 27 Nov 2004    Post subject: Muffling Reply with quote
Hey, I was wondering if anyone knew a reasonably simple technique to reduce sound from the engine. 80cc engine.
Possibly some sound obsorbing material at the end of exaust, anything.
mchaggis
PostPosted: 03:50 - 27 Nov 2004    Post subject: Reply with quote
What's wrong with the muffler it has just now?
Generally on a two-stroke they'd use a type of wire wool packed in varying size chambers along the length of the perforated inner pipe to absorb the high frequency noise in the fibre and the low frequencies in the gas spring effects of the chambers.
I must not be a troll...
Mmmm, Guinness
VPulse
PostPosted: 03:52 - 27 Nov 2004    Post subject: Reply with quote
Muffler works quite well, haven't tried it without it, but I was thinking more along the lines of further sound reduction if possible.
PostPosted: 04:01 - 27 Nov 2004    Post subject: Reply with quote
Well any further restrictions on the exhaust will make the bike less powerful and run worse. Has it got an after market race system fitted? I would say you're best bet is to get a system which is road legal as standard, lots less hassle and will work out cheaper or about the same.
VPulse
PostPosted: 04:05 - 27 Nov 2004    Post subject: Reply with quote
I do not beleive I have w/e that system is on. I was thinking something basic such as some sound obsorbing material a bit after the exaust end, or on it. It's not any high priority but it would be intresting to have a nearly silent system.
PostPosted: 04:12 - 27 Nov 2004    Post subject: Reply with quote
With a two stroke you change the way the exhaust works, which adding in extra baffling will do, you'll have to set up the fueling so its working as well as it can. It will sufocate it even more and would expect it to run like a heap of shit so if you are wanting to try modifying and breaking an exhaust I'd find one from a breakers going cheaply and use that as you won't be as bothered about having to chuck it in the bin.
cagiva gezzer
PostPosted: 10:28 - 27 Nov 2004    Post subject: Reply with quote
Put an extra length of pipe on the end and put a 90degree bend in to it so the sound pulse is forced towards the ground. Or, a 180 degree bend so the pulse is directed back under the seat.
stevo as b4
PostPosted: 17:48 - 27 Nov 2004    Post subject: Reply with quote
If its an expansion chamber type system, then lagging the expansion part of the pipe will help reduce the tinny sound from a 2 stroke, as manufactuers std chambers usually use this meathod with a layer of sound deadening material between two layers of metal, reducing noise and adding weight. The silencer does reduce the overall noise level, but as long as you use a straight through absorbstion type silencer it shouldnt matter what length or size it is, just make sure that the tailpipe diameter is not less than the std silencer.
TheShaggyDA
Repost Police
PostPosted: 17:51 - 27 Nov 2004    Post subject: Reply with quote
One has to wonder at why you want a silent bike.
hustler
PostPosted: 17:55 - 27 Nov 2004    Post subject: Reply with quote
He wants to make it like StreetHawk ... or am I thinking of the whisper of Airwolf Confused
As I said to that guy with the crutches and full camouflage gear, you can hide but you can't run.
VPulse
PostPosted: 18:41 - 27 Nov 2004    Post subject: Reply with quote
Thanks for the replies, il try out the suggestions sometime soon.
The last post was made 21 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 68.3 Kb
