| Rogue_Shadow |
 Rogue_Shadow World Chat Champion
 Posted: 10:46 - 02 May 2013 Post subject: Covering Accessory Cables |
Hey BCF
I've got a TomTom sat nav cable feeding under my tank to the handle bars, keeps it neat
However whenever the cable is not is use, it just sits above the forks hooked on one of the bikes cable tidies.
Can anyone recommend a cap or something I could fit to the cable end to prevent it getting mucked up/ wet for when it's not in use?
I remember seeing custom sized dust caps that you could slide onto the cable, then screw the other end of the cap up.
But Hell if I can find them any more
Something like blutak crossed my mind, but with the heat I can imagine it melting inside the pin.
Hopefully I'm not the first to come across the problem
Cheers |
| Scotsman37 |
 Scotsman37 World Chat Champion
| Fbyte |
 Fbyte Renault 5 Driver
 Posted: 15:04 - 02 May 2013 Post subject: |
Get a bottle of PlastiDip and make your own.
Custom fit  |
| map |
 map Mr Calendar
 Posted: 15:57 - 02 May 2013 Post subject: |
| Rogue_Shadow |
 Posted: 23:25 - 02 May 2013 Post subject: |
Cheers for the suggestions guys
Ideally I don't want to go down the route of fitting another socket or another connection onto the bike.
The plan is to run the standard TomTom cable from a 12v socket, with no other joins.
However it has given me an idea.
If I can get my hands on a female micro usb port, I could cut away the cable and make a case out of it.
So when my sat nav is not in use, I could plug it into the dummy port keeping the connections clean
Thanks again
The last post was made 13 years, 168 days ago. Instead of replying here, would creating a new thread be more useful? |
