| stuarthouston |
 stuarthouston Trackday Trickster
| Walloper |
 Walloper Super Spammer
| stuarthouston |
| Walloper |
 Posted: 11:41 - 03 May 2013 Post subject: |
| stuarthouston |
| Walloper |
 Posted: 13:41 - 03 May 2013 Post subject: |
| stuarthouston wrote: | | Walloper wrote: |
Go easy on the new clutch linings. Let them bed-in for about a hundred miles. No heavy hill starts or hoi-ing wheelies up the High Street.
Oil the plates and discs before assembly as they tend to soak up oil and stick when assembled. That can present a problem when setting up adjustment.
Clean engine oil. Change the oil. AND CLEAN OUT THE FECKIN' SCREEN TOO.  |
Hoi-ing wheelies up the High Street? I should be so lucky!
I've read that you should leave them to soak in oil overnight, yeah. Does that go for the steel plates as well as the friction ones? Is it worth cleaning up the steel plates with anything before they go back in? Again, I've read that a going over with really fine wet & dry isn't a bad idea?
Likewise, by the pictures in Haynes, it looks like the centrifugal oil filter sits slightly in front of the clutch. So, as it has to be dismantled and removed in order to get the clutch out, it'll get a good clean out in the process.  |
I'm not certain but the 'friction' plates could be 'coated' with sintered material. Sintered Iron, Bronze or similar. Some friction material is rubber based and treated to resist oil, heat, wear and such.
Soaking the friction plates allows time for oil to fill the micro-porous surfaces.
The oil is used mainly to carry heat away from the clutch. Obviously there is no need for lubrication between drive and driven surfaces via little grooves cut/cast into the friction material.
When engaged the oil is squeezed out from between the plates but sits in the pores. The friction material can still grip the steel plates in normal conditions and transmit full engine torque to the gearbox.
As the clutch plates wear the grooves/channels which radiate from the friction plate surfaces become shallower so oil cannot escape as easily which can allow the clutch to slip.
If the clutch slips it makes more heat, more heat can overcome clutch cooling and the friction material and or the steel plates get damaged.
Overloading a 'worn' clutch will accelerate damage.
There is a world wide debate on whether car engine oil is suitable for bikes. I would never use it as I could not be certain the lubricant modifiers in car oil will not harm the friction material.
For the sake of a wee bit more £s I stick to dedicated Bike Engine oil.
True story bro.
I have personnel experience of serious damage (millions of £/$) to off-road haul truck transmission and braking systems when engine oil was used (as OEM recommendation). The engine oil additives coated the friction material and caused 'partial' slip (only a few degrees) which eventually led to complete early hour failures world wide.
The remedy was a change to dedicated brake/transmission oil. Same grade of oil as engines use but minus the friction additives/improvers. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| moonzoomer |
 moonzoomer World Chat Champion
| DMCpro |
 DMCpro Traffic Copper
| Walloper |
| stuarthouston |
 Posted: 00:59 - 04 May 2013 Post subject: |
@Walloper: Yeah. It's been a little bit ropey for a couple of months now, but only when I went on a little country run the other week did I notice how bad it's gotten! Would rather get it sorted before the miles rack up over the summer. I've got 4l of a 5l bottle of oil left which was bought last service and matched up with all the specs in the book, so hopefully it'll be okay with the new clutch. Not bike specific stuff, but not posh stuff with lots of additives either. As you say, it's debatable whether it causes accelerated wear/slip. On something more powerful than a CG, I'd probably be more inclined to pay the extra...
@moonzoomer: Yes there is. And by the crud that was stuck in it last time I changed the oil, the centrifugal one is due a cleaning!
@DMCpro: Ordered one last week. Sadly, it's coming from China, so will probably be the biggest delay in getting the job done! Glad it's a straightforward task though!
Thanks for all the advice, gents. Much obliged to you all! ____________________ '96 Honda CG125 BR-T |
| DMCpro |
| stuarthouston |
 Posted: 21:53 - 12 May 2013 Post subject: |
Finally got all the bits together to do this yesterday, got to the stage of removing the centrifugal oil filter cap, and one of the screws is so chewed that I can't get any purchase on it at all. If I just drill the bugger out, will there be enough of a stump left to get vice grips on to to remove the rest?
These screws feel like they are made of cheese. Gah!  ____________________ '96 Honda CG125 BR-T |
| DMCpro |
| humanbeing |
 humanbeing Nova Slayer
 Posted: 03:54 - 13 May 2013 Post subject: |
| tomh |
 tomh Scooby Slapper
| Walloper |
 Posted: 09:21 - 13 May 2013 Post subject: |
I hate watching/listening to folk to tap, tap then hit something with a hammer. Just fcaking HIT the facking thing...  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| stuarthouston |
 Posted: 12:15 - 13 May 2013 Post subject: |
Thanks chaps. Shall have a go at it today armed with a drill. My patience wore out with it last night and I knew, if I kept going, I was just going to break something.
All three screws were pretty chewed when I took the clutch cover off. Two of them came with a bit of persuasion, but the third was beyond saving. Baffles me why people put fixings back that are worn to that extent! At least I know the oil spinner has been cleaned in the past, though!  ____________________ '96 Honda CG125 BR-T |
| Walloper |
 Posted: 12:40 - 13 May 2013 Post subject: |
| stuarthouston |
 Posted: 23:57 - 13 May 2013 Post subject: |
Finished putting it back together this evening. Spent a mighty £2.55 on new screws for the spinner! Ended up drilling a 4mm well in to the chewed screwhead and tapping a T27 Torx bit in to it to unscrew it. Worked a treat!
Happy to report that the EBC clutch and springs are great. Stuck a new cable on as well for good measure and it all feels far happier than before, so thanks to all for the recommendations/tips!  ____________________ '96 Honda CG125 BR-T |
| Walloper |
| stuarthouston |
| Walloper |
 Posted: 21:14 - 14 May 2013 Post subject: |
| DMCpro |
| Walloper |
The last post was made 13 years, 56 days ago. Instead of replying here, would creating a new thread be more useful? |
