Over Taking?
Rodger Wabbit
PostPosted: 17:16 - 27 Nov 2004    Post subject: Over Taking? Reply with quote
Hi, Went out for a ride today and was practicing overtaking cars, was getting more confident when i through right i can overtake this car. "another car was coming the other way" so i pull out get half way past, changed gear and and loose all power (think its that false neutral thing) ! o dear cars coming fast the other way and iv got no power to overtake this car and his not going to let me back in! luckly i manage to get the gear and just get in front of the car but only just! and im sure i caused both cars to slow down Embarassed !
So have you lot ever had any interesting overtaking problems?
iCraig
PostPosted: 17:20 - 27 Nov 2004    Post subject: Reply with quote
As some people may tell you on this forum who went on the wales rideout, that I cut my overtakes quite fine. Very Happy
I mean fine as in not alot of space between me, the oncoming vehicle and vehicle I'm overtaking. Its one of my bad habits unfortunatly and a plus of owning a slim bike. Razz
Bendy
Mrs Sensible
PostPosted: 17:29 - 27 Nov 2004    Post subject: Reply with quote
The exhaust fell off my car once, as I was in the middle of overtaking an oil tanker lorry with oncoming vehicles. That was 'interesting'. Always good to find yourself suddenly with no power and a large piece of metal dragging along the deck. Confused
hustler
PostPosted: 17:35 - 27 Nov 2004    Post subject: Re: Over Taking? Reply with quote
Theres your first mistake .. changing gear half way through an overtaking manoeuver. Select the right gear before, its much easier that way.
Needless to say I've had a few close overtakes, although most have been in car. Bikes are too quick generally and your TED (Time Exposed to Danger) during overtakes is much smaller than in a car (plus they take up less space if you get it badly wrong and it ends up a squeeze)
As I said to that guy with the crutches and full camouflage gear, you can hide but you can't run.
Ant
PostPosted: 17:36 - 27 Nov 2004    Post subject: Reply with quote
i once overtook a lorry and when halfway up the side of him (and half way round the bend by this point) a lorry was comming the mother way, luckily for me, there was enough room down the middle for me but it was a shut your eyes and think oh fuck moment!
04 ZX10R ~
Silver
PostPosted: 18:18 - 27 Nov 2004    Post subject: Reply with quote
I was in the middle lane of the M40 (in my car) a few years ago doing about 85-90mph when the bonnet flipped up and smashed the windscreen. I was overtaking a lorry at the time. Luckily he saw what happened and slowed right down - my bonnet was still up and I couldn't see where I was going!
That woke me up... I don't really need that kind of shite first thing in the morning on the way to work!
PostPosted: 18:31 - 27 Nov 2004    Post subject: Reply with quote
There is always the old trick of 'going onto reserve as you pull alongside the car you are overtaking' which can be embarassing.
The problem Roger Wabbit had can be pretty much avoided by a bit more planning, the trick is to leave more of a gap between yourself and the car. As you see a safe overtaking point coming up you accelerate into the gap in front of you meaning that by the time you pull out to pass, you are already up to a speed that will allow you to safely complete the overtake.
A bit of a stab in the dark here, but I bet Roger did a direct access test with no significant amount of road experience on a 125. The reason I say this is because for learners on 125s, the above technique is a 'bread and butter' one, the only way you can get past slower moving vehicles. You often had to start your 'attack run' two corners before the overtaking site in anticipation of the road being free of oncoming traffic. As you rounded the corner the little bike would be totally flat-out and the distance timed perfectly to nip out as soon as the way ahead was clear whilst still leaving space to abort the manouver if there was something coming.
Rodger Wabbit
PostPosted: 18:44 - 27 Nov 2004    Post subject: Reply with quote
Yup You would be right. Shocked
PostPosted: 18:56 - 27 Nov 2004    Post subject: Reply with quote
*buffs fingernails nonchalantly on jumper* Wink
cagiva gezzer
PostPosted: 19:01 - 27 Nov 2004    Post subject: Reply with quote
I agree with stinkwheel.
You've got a serious prob if you can't get past a car when you're on a proper bike. Just work the engine more.
Most people pick up the technique on smaller bikes, because if you don't learn how to, you will bever get past other traffic.
Try doing it on 50mph 50cc! Spot the prey in the distance, spot the overtaking area 1 mile ahead, build up speed, time it just right so you get to the prey just before the overtake area and pull out past. An thats just for cyclists! Wink
PostPosted: 19:03 - 27 Nov 2004    Post subject: Reply with quote
If you can't complete and overtake and the car you're overtaking there is one easy option. Brake to slow you down and slot back in behind the car you were overtaking.
mchaggis
PostPosted: 19:08 - 27 Nov 2004    Post subject: Reply with quote
My problem is making sure I've seen them before they overtake me. Laughing Sometimes they cut it a little too close, when you can feel the wind from their wing mirror going past your elbow, it's not a confidence inspiring thing.
Most of the little overtaking I do is stretching the bike to its limits, and then the traffic is right up my backside as soon as we get onto a long straight bit. Overtaking a cement lorry because he was spraying me with muck and that horrible fine mist and then he overtaking me again was somewhat embarrassing.
I must not be a troll...
Mmmm, Guinness
Gazdaman
I did a trackday!!!
PostPosted: 21:11 - 27 Nov 2004    Post subject: Reply with quote
Knowing your bike really helps when making the overtakes.
I know that between 30 and 45 in third gear is the best for me to overtake in.
I also know I have to take a bit of a run up to just nip past.
As I'm getting more confident I'm overtaking more, sometimes I really don't want to commit to it and I just slot back in behind the car I was behind originally.
You'll also find the best time to overtake is coming out of a corner, that's when I zap 75% of slower moving vehicles.
Gaz
Rob W
PostPosted: 21:18 - 27 Nov 2004    Post subject: Reply with quote
I used to overtake everything (doing less than 40 anyway Rolling Eyes ) when I had my TS50, used to ride that thing like a loon, being 16 and thinking I was invincible.
Not too worried about getting past anyone now unless I have to, cant see how people have problems getting by though. Knowing your bike is best IMO, only go for it if you know you can easily out accelerate them to get past at your given speed.
kasandrich
PostPosted: 21:31 - 27 Nov 2004    Post subject: Reply with quote
Well, I'm sitting reading the Police riders handbook to better motorcycling, which is the "Bible" used for the IAM advanced Motorcycling test.
........the thrash it to bits for two miles, to try and pick up a bit more speed than the car ahead, then nip out at the last minute and back in the other side, with the option to cancel if anyone else should decide to use the road, technique that you describe does not appear!
The recommendation is to pull out when you can see it is clear to complete the manouvre, once out in the road with a clear path ahead, increase your speed to one suitable to overtake in the distance you can see to be clear, select the appropriate gear for that speed, then once past, pull back in.
Yes I did do a DAS test, and now I'm taking more training to move on to an Advanced test.
Richard
CBR1000FM
skyline
PostPosted: 22:03 - 27 Nov 2004    Post subject: Reply with quote
lol, i was exactly the same, then i got a 400, and i remember after a month or so i had another go on a 50 and couldnt dare even try and overtake a car run up or no run up (yes i agree the run up to the car idea works well on slower bikes) because i didnt think there would ever be enough room :S
PostPosted: 22:50 - 27 Nov 2004    Post subject: Reply with quote
...... technique that you describe does not appear!
Yes, but they advocate a lot of things on advanced riding, many of which the IAM can't agree on amongst themselves. There is no such thing as a be-all and end-all rulebook, find something that works for you which is safe and legal and do it. It is a technique I use to good effect all the time in real life, unobserved, unasessed motorcycling.
A couple of examples of slightly questionable techniques alternatley taught then not taught in the IAM include offsiding which I have discussed previously and the practice of flashing your headlamp prior to overtaking which in my experience generally makes the vehicle you are about to overtake suddenly slow down. I have done both in the past, I now seldom do either.
My advice is to practice what they teach and take from it what you agree with and are comfortable with
Advanced motorcycling admittedly helps many people to be safer riders and focuses attention on overlooked aspects of roadcraft but it is neither definitive or universal.
I remember clearly when I was doing my test on a 125 (quite a few years ago now), the instructors debating the correct road positioning when negotiating a right hand stacker lane. 'The book' said you should remain in the centre of the lane, I pointed out that this would mean you braking whilst riding along the big white 'right turn' arrow that is painted there. I believe this caused considerable discussion at their next IAM meeting.
Stinkwheel
10 years No-Claims
Villers
PostPosted: 22:57 - 27 Nov 2004    Post subject: Reply with quote
The coppers on the bikesafe claimed to ride about a foot from the white line, except when going through bends. This gives you a better view of the road ahead and puts you in both mirrors of the driver. The IAM instructor guy that showed the video of himself riding his busa had advice on the overtaking thing too. First of all he overtook without breaking his stride, no accelleration, no gear change - nothing! He also said not to indicate as 'by the time they see it your already doing it'. Anyway their method was to overtake gracefully and quite slowly so as not to over commit and give you chance to pull back in if a crisis arrives.
My own personal method is to have a quick look, then flog the @rse out of it and wring its neck until your past in the shortest possible time! Wink
jonboy
PostPosted: 23:01 - 27 Nov 2004    Post subject: Reply with quote
The police riders handbook doesn't even mention countersteering either, which completely removes any faith I may have had in it once.
hustler
PostPosted: 23:08 - 27 Nov 2004    Post subject: Reply with quote
stinkwheel wrote:
... and the practice of flashing your headlamp prior to overtaking which in my experience generally makes the vehicle you are about to overtake suddenly slow down.
I think thats actually to draw the attention to the vehicle in front thats somethings going on behind them, I wouldn't have thought most people would have slowed down Question
Agreed Thumbs Up
kasandrich
There are sound explanations for not doing the "run up" technique to overtakng, and that is that you never put yourself in the position where you are fast approaching the rear of a car or lorry, in the same lane and possibly (if a car appears in the opposite direction) with nowhere to go.
By seeing the way is clear, then pulling out, then accelerating selecting the right gear for your speed, then passing the vehicle and pulling in, you may be out in the other lane longer, but you are travelling at similar speeds, and can therefore easily cancel the manouvre and pull back in on your approach. But you cannot put yourself in the position that you are aproaching the vehicle in front at 20mph or more, then find you have nowhere to go, then maybe a diesel spill, or a wet drain cover or some simple everyday road hazard and you are in trouble.
I would suggest that if that techniqe is not possible then you need a more powerfull machine or the overtake isn't really on safely. where is the element in reserve, for contingency?, you are advocating taking a run up flat out, with no power in reserve.
Richard
CBR1000FM
jonboy
PostPosted: 23:12 - 27 Nov 2004    Post subject: Reply with quote
I would suggest only overtaking in the car. If you think about likely you are to suffer a serious injury if someone clips you on the bike, compared to maybe a dinged wing in the car, it is obvious that two wheelers shoudn't be allowed on the road. Totally dangerous things.
Alternatively we could ban riding bikes until riders are 25, then they could jump straight on a bike with ample power for overtakes.
kasandrich
PostPosted: 23:16 - 27 Nov 2004    Post subject: Reply with quote
Whilst I agree that it is not mentioned in the book, the book is about roadcraft, and road safety not how to ride. It is certainly advocated by IAM observers.
Richard
CBR1000FM
PostPosted: 23:20 - 27 Nov 2004    Post subject: Reply with quote
So essentially the same thing, he will be going maybe up to 20mph faster than the traffic he is passing as he overtakes. He will have spotted the oppertunity to overtake maybe 1/2 mile before he arrives and adjusts his speed slightly so he comes up on the car at the right speed at the exact moment the way is clear. This equates to my 'gap' (but maybe a bit poorly worded).
There is always what pilots refer to as a 'go/no-go' point, you have to know where this is and if you aren't absolutley sure you can make the manouver stick, back off.
EDIT: In this way, unlike some other ways I have seen advocated, you either make a smooth overtake or do not move out into the opposite lane at-all. :EDIT
On a 125 you just have to flog the arse off it so you have max-V as you get up behind the car and slingshot round it. In my purely anecdotal experience neither the police or the IAM have anything usefull to say about overtaking on a small capacity bike other than buy a bigger one.
jonboy
PostPosted: 23:28 - 27 Nov 2004    Post subject: Reply with quote
^^exackerly.
Whether you have a big or small bike, you would still aim to end up overtaking the car going a certain amount faster. The small bike technique simply takes longer to build up that speed.
As long as the forward visibilty is adequate, there's no reason slingshotting should be in the least bit less safe.
The last post was made 21 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 138.44 Kb
