Cyclone remote start installation
J.M.
PostPosted: 18:42 - 04 May 2013    Post subject: Cyclone remote start installation Reply with quote
So I've installed the Cyclone alarm that I bought. Figured out why my starter button was working so intermittently in the process and fixed that. The instructions that came with the cyclone mean that when the starter button is pressed, it will start regardless of being in gear or not. This is not what I want.
Here is the wiring diagram:
https://i.imgur.com/1bQVslr.jpg?1
The instructions told me to attach the remote start wire to the blue-white wire going to the start relay.
Instead I attached it to the other blue-white wire coming out of the relay assembly and leading to the starter switch. This wire should have no voltage going through it when any of the safety devices are in action (I.E. side stand switch, cut off switch). However the remote start still seems to be starting the bike whilst it's in gear (I tested with me sitting on the bike so that it didn't fall).
The bike starts by earthing that blue wire - and this is what the alarm does.
I'm 99% sure I got the correct wire (I tested). What did I do wrong?
2004 R1 & 2018 XSR900
CaNsA
PostPosted: 18:44 - 04 May 2013    Post subject: Reply with quote
You connected in the first place, that's where you went wrong.
I didnt bother on mine, it's pointless gimmicky and risky IMO.
The alarm works fine with out it.
J.M.
PostPosted: 18:48 - 04 May 2013    Post subject: Reply with quote
Yeah but the thieving bastards broke my ignition, so this saves buying a new one. Otherwise I have to keep my ignition barrel in my tank bag whilst I ride.
CaNsA
PostPosted: 18:53 - 04 May 2013    Post subject: Reply with quote
The side stand switch is a good place to use
If the bike is in gear, and the stand is down it wont start.
Can you post a pic of the alarm installation guide ?
andy_uk
PostPosted: 19:00 - 04 May 2013    Post subject: Reply with quote
Not ideal, but a workaround would be as follows :
Connect a relay to the neutral light.
Connect the starter switch wire from the Cyclone to the 'normally open' contact.
Connect the 'common' contact to where you currently have the starter wire connected.
CaNsA
PostPosted: 19:01 - 04 May 2013    Post subject: Reply with quote
Or just connect 1 wire to one side of the sidestand switch.
I need the alarm wiring diagram to know which side.
J.M.
PostPosted: 19:14 - 04 May 2013    Post subject: Reply with quote
The side stand switch will not work as far as I can tell. The side stand cuts the power in the exact same way that the bike starts. This bike requires the blue-white wire to be earthed which then closes the starter relay which then starts the bike. So by connecting it to the side stand switch, pressing the starter button would effectively circumvent it?
The diagram is the same for all cyclones, it never changes. The instructions are:
1 - connect the blue wire to the blue/white wire going to the starter relay
2 - [finding the ignition fuse] and leave the ignition fuse out
3 - Connect the brown and pink wires to the live side of the ignition fuse
4 - Connect the grey wire to the other side
5 - Connect the small blue wire to the small black wire by the cyclone box
So the cyclone blue wire creates a ground circuit rather than supplying +12v like on other bikes. That's the purpose of the black wire as far as I can tell.
Yeah that would work, but I'm convinced there is a simpler/more elegant way to do it!
CaNsA
PostPosted: 19:29 - 04 May 2013    Post subject: Reply with quote
I would do a bit of trial and error.
Get the rear wheel up and test both sides of the sidestand with that wire which is supposed to hook into the starter relay.
You are trying to install it in such a way that it doesnt bypass the safety feature of not starting and jumping forward while in gear when started.
With the ignition circuit being messed with already, what have you got to lose?
J.M.
PostPosted: 19:48 - 04 May 2013    Post subject: Reply with quote
Unfortunately I have nothing to raise the rear wheel, so I can only test things whilst I'm sitting on the bike, so make sure that it doesn't fall.
From studying the diagram it appears that the left relay in the relay assembly should only close when the clutch switch and side stand is earthed and the clutch switch is closed. (Although the clutch switch has never been in use... maybe that's bypassed by the previous owner).
Then the blue-white wire leading to the starter switch should only have +12v when the clutch switch is closed and the side stand switch is down. The blue-white wire to the starter relay will always have +12v (even if the ignition is off).
I just don't understand it because installing it in place of the starter switch and only the starter switch should make it function exactly the same as the starter switch Confused
I will get outside and experiment again tomorrow.
J.M.
PostPosted: 13:36 - 05 May 2013    Post subject: Reply with quote
You know how sometimes.. you just feel like a complete idiot?
Well... Laughing
It was all working. Turns out the previous owner disabled the clutch switch and I was subconsciously putting the side stand up every time I climbed over the bike. Tried it with the side stand down... worked perfectly. Doh!
https://i.imgur.com/N9hAZ63.jpg
CaNsA
PostPosted: 15:19 - 05 May 2013    Post subject: Reply with quote
https://i.imgur.com/EegC0Mr.png
J.M.
PostPosted: 16:15 - 05 May 2013    Post subject: Reply with quote
Loving the creativity in the new NSFW BCF insults. Laughing
The last post was made 13 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 74.3 Kb
