| Shillz |
 Shillz Two Stroke Sniffer
| fatpies |
 fatpies World Chat Champion
| Matt B |
 Matt B World Chat Champion
| Shillz |
| Matt B |
| Shillz |
| Matt B |
| Shillz |
| jeddy11 |
 jeddy11 Traffic Copper
 Posted: 15:12 - 05 May 2013 Post subject: |
its best if they were still conected then you can just pull the brake lever until one is nearly popped out then brace that with some wood and keep pumping untill the other one falls out then they should just need tweaking out...
If you try to grip those pistons with pliers or pump grips etc your likely to damage them unless you can find someone with a pair of internal piston pliers..
hope that helps a little ____________________ Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!! |
| c_dug |
 c_dug Super Spammer
| Islander |
 Islander World Chat Champion
| Shillz |
| trisers |
 trisers Scooby Slapper
| trisers |
 Posted: 23:20 - 05 May 2013 Post subject: |
Incidentally...i used various things of increasingly thinner size to wedge the piston that was coming out first and found they all move so the face of them is nearly level with the face of the opposite (cut-out) side of the caliper. In fact my steel rule which is only about 1mm thick was enough to stop the pistons popping out but got them all to the point that they could just be worked out by hand  |
The last post was made 13 years, 194 days ago. Instead of replying here, would creating a new thread be more useful? |
