honda cbr1100xx rear caliper removal
Mrjoolz
PostPosted: 16:46 - 05 May 2013    Post subject: honda cbr1100xx rear caliper removal Reply with quote
How?
Undid one bolt nope. Where are other bolts? Need to change rear pads and cannot get the fooking thing off.
Help !!!!!!!
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
Scotsman37
PostPosted: 08:37 - 06 May 2013    Post subject: Reply with quote
I found this guide on another forum that may help you!
Re: Bird rear caliper..how do ya get it off??
If you want to remove the caliper from the carrier without removing the wheel you need to undo the bolt at the end nearest the shock (possibly a 14mm head), at the far top left side (looking from the right side of the bike) is a small black rubber plug, remove this to get access to a pin which holds the rear edges of the brake pads in place. This pin has an allen key head and unscrews in the normal anti-clockwise direction. The last thing is the sliding bolt which sits about half way along the caliper body near the bottom edge and has a rubber sleeve around it. It you tease the rubber cover back slightly towards the silencer you will see a 12 or 13mm bolt which you will need an open-ended spanner to undo. Once these 3 things have been undone the caliper and pads should lift off.
Mrjoolz
PostPosted: 06:47 - 07 May 2013    Post subject: Reply with quote
Cheers, I'll take a look and try that.
Thanks a lot.
The last post was made 13 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 35.03 Kb
