| koolio |
 koolio Spanner Monkey
 Posted: 22:21 - 06 May 2013 Post subject: Aluminium polishing - autsol vs compound bars |
Decided to pull out my polisher and do some of the polishing myself, it is a powerful machine with high rotations.
Looks like the kit below but bigger:
https://i365.photobucket.com/albums/oo91/ModMindedShare/Nzxt%20Lexa/Plexi/PolishingSetup3inuse.jpg
I'm no expert but in the past I've polished with brown and blue bars. On this occasion I'm stuck with Solvol autosol.
First thing I've noticed is it's blackened all the polishing wheels. I'm not after a mirror finish but it's not doing a bad job if not messier than the bars.
Question is this should I really be using solvol autosol for this application and is it ruining my polishing wheels? Can I switch back to the compound bars now the wheels have been blackened and impregnated with solvol? |
| Walloper |
 Walloper Super Spammer
 Posted: 22:29 - 06 May 2013 Post subject: Re: Aluminium polishing - autsol vs compound bars |
| koolio wrote: | Decided to pull out my polisher and do some of the polishing myself, it is a powerful machine with high rotations.
Aluminimum need a different abrasive as it is soft and tends to clog.
Autosol is recommended for aluminimum.
It 'says' it also 'protects' the polished finish from air after the job is done.
 ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| koolio |
| mudcow007 |
 mudcow007 World Chat Champion
| Walloper |
| koolio |
| mudcow007 |
| map |
 map Mr Calendar
| Ichy |
 Ichy World Chat Champion
 Posted: 17:33 - 07 May 2013 Post subject: |
Autosol will work with good but tarnished aluminium but it will not help with removing blemishes, not without generating a lot of heat.
Brown is your general purpose compound, I think it is called something like tripoli? The abrasives help to cut into the surface of softer metals. Blue is more of a finishing compound, more of a final polish. I don't think it has abrasives in it?
What mops are you using? They can make a difference. Always use different mops with different compounds, obvious really.
Some years ago I was given a big lump of a grey compound. No idea what it is but it works really well on pitted and corroded aluminium.
I find that meths oxidises the polished surface enough to stop it corroding but without affecting the shine too much. Pure Ethanol is supposed to be better but I've never tried it. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| koolio |
| Ichy |
| Pete. |
 Pete. Super Spammer
 Posted: 22:46 - 07 May 2013 Post subject: |
Yes a LOT longer.
If you must indulge in this particular brand of masochism (can't stand doing it myself), invest in a large bench grinder - the bigger and the older the better - and get a supply of proper wheels and soaps. And a decent pair of gauntlets & safety specs too. Some people take a hefty single-phase motor and fit their wheel either to that or to a shaft it's driving.
2-pole motors are 2800rpm, 4-pole are 1450rpm.
do a search for 'buffbook' and you'll find a handy pdf. ____________________ a.k.a 'Geri'
| Walloper |
| Pete. |
 Pete. Super Spammer
| mudcow007 |
| koolio |
 Posted: 09:32 - 08 May 2013 Post subject: |
Very well! Here she is 3000-3600rpm very proud of her.
Can you see the mops blackened and impregnated from the autosol? Is there a way of cleaning them and returning to the compound bars, or should I just go straight back to compound?
I was using brown on the stitched side and blue on the loose leaf side before autosol threw spanners in my world!!
https://i747.photobucket.com/albums/xx115/accjnt/Polisher/IMG_3657_zpsd6a39997.jpg |
| koolio |
| Pete. |
 Pete. Super Spammer
 Posted: 20:45 - 09 May 2013 Post subject: |
Newspaper gets the black off, apparently. I never tried it. ____________________ a.k.a 'Geri'
| harscot |
 harscot Crazy Courier
 Posted: 11:14 - 10 May 2013 Post subject: |
Try Tcut, used it on everything from exhaust to wheels and even plastics, works a treat and everything is gleaming and seems to last an age.  ____________________ First bike R reg Suzuki 125 GT twin in 1978:
2nd bike X reg Honda 650 Deauville in 2011:
Wish bike a Triumph Thunderbird: Dream bike Triumph Rocket........ |
| mudcow007 |
| koolio |
 Posted: 13:04 - 10 May 2013 Post subject: |
But mine has bigger wheels!  |
The last post was made 13 years, 54 days ago. Instead of replying here, would creating a new thread be more useful? |
