Removing brake calliper - best way to stop fluid?
map
Mr Calendar
PostPosted: 11:33 - 07 May 2013    Post subject: Removing brake calliper - best way to stop fluid? Reply with quote
I need to remove a brake calliper to refurb it with new seals.
When taking off a brake calliper what methods to people use to stop the brake fluid totally spewing out all over.
It appears to be something glossed over in all the how-to instructions.
In the past I've used a plastic bag and secured with elastic bands around the brake line. Still found that messy though.
Any better solutions?
Islander
PostPosted: 11:52 - 07 May 2013    Post subject: Reply with quote
I just use a plastic bag and tie wrap. I don't find it particularly messy.
charlie74
PostPosted: 14:18 - 07 May 2013    Post subject: Reply with quote
brake hose clamp.... Rolling Eyes
Robby
Dirty Old Man
PostPosted: 14:20 - 07 May 2013    Post subject: Reply with quote
I hold it over a drain bowl while I'm pumping out the pistons, then let the lines dangle over the bowl while I'm working on it.
If the fluid is really old and grotty then consider cleaning out the master cylinder while you're at it. Old grotty brake fluid can block, or partially block, the small holes in the master cylinder and make it a bastard to bleed afterwards.
Aff
PostPosted: 14:28 - 07 May 2013    Post subject: Reply with quote
Get some long nosed vice grips with the end wrapped in an inner tube or something to stop the teeth doing damage.
Or just let it drain into a bucket and replace the fluid.
Electric Bike Project
andym
PostPosted: 15:48 - 07 May 2013    Post subject: Reply with quote
Silly question, with the clamp method... wouldn't that damage braided hoses?
I always just let it drain (into a container if I'm feeling tidy... or just on the floor when I was working in the thieving c**ts garage)
Ja7
PostPosted: 16:09 - 07 May 2013    Post subject: Reply with quote
+ 1 I have also done this
Matt B
PostPosted: 16:14 - 07 May 2013    Post subject: Reply with quote
Old 2 litre drink bottle, just stick the braided hose in it. It doesn't exactly spew out anyway.
If you are bothering to refurb the caliper you may as well (should really) replace the fluid anyway.
CaNsA
PostPosted: 16:33 - 07 May 2013    Post subject: Reply with quote
Rolling Eyes
Teflon-Mike
tl;dr
PostPosted: 16:59 - 07 May 2013    Post subject: Reply with quote
Tape a pop bottle over the end, drain fluid out.
Hardly worth trying to save old fluid since you'll have to prime & bleed system after putting overhauled caliper back on.
You just want to leave enough old in there to stop master cyl seals drying out.
lukamon
PostPosted: 17:02 - 07 May 2013    Post subject: Reply with quote
OR
since not everyone has a brake hose clamp, you can easily make your own with two small 1/4 in drive sockets, put one either side of the line, clamp down and lock with a set of mole grips, job jobbed.
killa wrote: Im an ass man myself
iooi
PostPosted: 17:39 - 07 May 2013    Post subject: Reply with quote
Or......
Keep the open end ABOVE the brake master block. Mr. Green
Walloper
PostPosted: 18:05 - 07 May 2013    Post subject: Reply with quote
Mash the open ends of the pipes flat between two hammers. Thumbs Up
andym
PostPosted: 19:59 - 07 May 2013    Post subject: Reply with quote
Hmmmm.... I like your thinking
The last post was made 13 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 81.86 Kb
