Broken down... but fixed itself!
matto
PostPosted: 15:19 - 07 May 2013    Post subject: Broken down... but fixed itself! Reply with quote
On my way to work this morning I had to stop off and pick up some bits from one site before heading to another for some training. I left the first site and was going reasonable slowly through traffic. Got out onto a more main road open the throttle and had a little backfire. The bike then proceeded to back fire four or five times and then cut out. Got the clutch in and coasted for a bit, tried to restart but nothing, so pulled over the side of the road.
Tried starting the bike a couple of times and it was very relucatant to turn over and was certainly not going to start, so I started to try and call ahead to let work know I was going to be late. Due to not having the number and the ladies that work on the main switchboard being utterly useless this took me 10-15mins. Once I'd finished the call I had another go at starting the bike...
...and it worked fine, in fact after the traning I've done about 30miles on it today and have taken it for a MOT (almost passed, just little things) Anyone got any idea what could've caused this randomness? and how I can prevent it happening again? It's a '96 Aprilia Pegaso 650, with a new sprag/starter clutch and recently rebuilt carbs.
Aff
PostPosted: 15:32 - 07 May 2013    Post subject: Reply with quote
Sticking/badly set up carb float causing it to flood?
Electric Bike Project
map
Mr Calendar
PostPosted: 15:33 - 07 May 2013    Post subject: Reply with quote
Had a hiccup with one of my old bikes similar symptoms.
Found out a little later it was the coil on its way out.
This may or may not be the same but something to poke at.
Usually though with intermittent faults they're a right PITA. It's actually easier to diagnose and fix something that's totally broken rather than just failing.
matto
PostPosted: 16:27 - 07 May 2013    Post subject: Reply with quote
Don't think it could be the carb float, but the coil is a distinct possibility, as it would explain the reluctance to start... but how would a coil cause a bunch of backfires?
map
Mr Calendar
PostPosted: 16:30 - 07 May 2013    Post subject: Reply with quote
Found this for cars but an ignition coil is an ignition coil...
Ignition coil failure symptoms - click me
HTH Thumbs Up
andym
PostPosted: 16:44 - 07 May 2013    Post subject: Reply with quote
HTH Thumbs Up
Sorry to hijack the thread a little, that link you provided map, would the bike show all of those symptoms or some?
I don't have any backfires, not sure about the fuel economy and a couple of the others.
But my bike has a habit of cutting out sometimes when idling after it's been running for a while, and refuses to start until the bike has cooled (has a habit of flattening the battery before starting and will not bump start no matter how big the hill is).
Also not sure if it would count, but even on a day like today I need to use the choke to start the bike (which will usually start within a couple of seconds)
map
Mr Calendar
PostPosted: 16:51 - 07 May 2013    Post subject: Reply with quote
andym wrote:
Sorry to hijack the thread a little...my bike has a habit of cutting out sometimes when idling after it's been running for a while, and refuses to start until the bike has cooled (has a habit of flattening the battery before starting and will not bump start no matter how big the hill is)...
What bike?
If I was to guess, which I am, it sounds a bit like a 2-stroke starting to seize.
More info needed (e.g. how long, any other changes, make, model, age) and perhaps asking older/wiser/experienced heads via its own thread in Workshop?
andym
PostPosted: 17:00 - 07 May 2013    Post subject: Reply with quote
map wrote:
What bike?
Close, zxr750. I just read the link you provided and some of the symptoms are spot on, others not that I've noticed. But for 10 minutes work, then it's worth a try (well maybe 15 if I trim the leads back to fresh copper)
matto
PostPosted: 13:32 - 08 May 2013    Post subject: Reply with quote
I've taken some advice and it appears that upgrading to a Dyna-coil is a great idea on an old big single regardless of if the current one is slowly breaking.
However I have no idea how to work out which dyna coil I should get, beyond being a single output one, how do I find out what primary and secondary resistances my old coil had?
matto
PostPosted: 13:36 - 08 May 2013    Post subject: Reply with quote
Ignore me, I found an rotax manual.
primary 0.2 to 0.5 ohm
secondary 6 to 13 ohm
so I guess I should aim to get something with figures between those values?
Islander
PostPosted: 13:42 - 08 May 2013    Post subject: Reply with quote
Yes, those are limits so anything that's between or those figures will pass.
matto
PostPosted: 14:28 - 08 May 2013    Post subject: Reply with quote
One last stupid question! Would a coil with a 14k secondary resistance be a terrible thing if the limit in the book is 13k?
cb1rocket
PostPosted: 22:48 - 08 May 2013    Post subject: Reply with quote
another 1000 ohms but always worth a shot. I have had coils that had totally different specs from a Chinese bike. Fitted it to my jap Honda, worked no problems!
matto
PostPosted: 17:11 - 09 May 2013    Post subject: Reply with quote
Well I've ordered a new plug cap, leads and a mini Dyna Coil DC12.
It has a 0.5ohm primary and 11.7k ohm secondary, unfortunately the new plug cap is 5k ohm rather than the 1k ohm original but I think it should work... I guess I'll try anyway.
Cheers for the help, I will update when all the parts arrive.
matto
PostPosted: 19:09 - 17 May 2013    Post subject: Reply with quote
Well I've wired it all up and had it started, might be a placebo effect but it sounded crisper (can't think of a better way of describing it) and I was able to take it off the choke after about 30sec of running...
...however it's way bigger than the original coil and I really can't see an obvious way of attaching it to the bike and fitting the fuel tank over it. The further I move it from it's original position the longer the sparkplug lead has to be, which can't be good for resistance.
Going to have to go stare at it and scratch my head a bit more Very Happy
cb1rocket
PostPosted: 20:11 - 17 May 2013    Post subject: Reply with quote
good news but you should of got one the same size Laughing
picture of original? I'm sure you can find one to match
map
Mr Calendar
PostPosted: 21:04 - 17 May 2013    Post subject: Reply with quote
About £50 on eBay - example click here.
Breaker 2nd hand may be cheaper or if there are any alternative aftermarket kit with same size/specs.
matto
PostPosted: 22:53 - 17 May 2013    Post subject: Reply with quote
The new dyna coil was only £75 so getting a second hand one seems a bit silly considering the original is broken. It's a minature dyna coil too, so the smallest they do!
Anyway after much thinking I have made a little bracket and have managed to attach it at such an angle that you can just squeeze the tank back on, will take it for a run at some point in the next couple of days and see what improvement there is.
The last post was made 13 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 100.06 Kb
