| trh71 |
 trh71 Derestricted Danger
 Posted: 19:24 - 07 May 2013 Post subject: Help in setting up a suzuki ts50 70 big bore kit |
Hi all
I picked up a ts50 for my lad, but it struggled to do 30? It turned out it had been "messed" with. Some idiot had been in with a dremel, inlet, outlet, ports underneath and not tidy!
So I've picked up a good 2nd hand 70cc barrel & piston and also a Dep exhaust.
I'm running a K&N type air filter, the carb is 15mm (is this standard?)
It had 95 main and 12.5 pilot jets in and a hotter plug (7).
It wouldn't kick off, but I bumped it off and it ran but wouldn't tick over.
I've got a 17.5 pilot and 115 main in, it kicks with a bit of throttle, but wont tick over under 3k
Am I right or am I going too big, or do I still need bigger??
The other thing is oil mixture via oil pump
Its doing my head in  |
| DMCpro |
 DMCpro Traffic Copper
| trh71 |
| smegballs |
 smegballs World Chat Champion
 Posted: 20:44 - 07 May 2013 Post subject: |
| trh71 wrote: | Yes I still have it, but thought a K&N cone filter would be better? |
The problem you see is that you are changing more that one variable at a time. Is it running shit due to the 70 kit or is it running shit due to the k&n?
Restore it back to stock, so that the only change is the 70 kit. Then once you have dialled in the jetting for the 70 kit, and got it running as good as it will go, that is the time to put on the k&n (if you want to) and dial in the jetting for the k&n, filter.
If you have changed two things at a time, you can't tell your arse from your elbow and will waste loads of time, chasing your tail because you don't know what changes are having what effects.
A scientific, methodical approach is needed, although personally after trying to downgrade my 300cc MZ to a 250cc I'll be perfectly happy if I never have to "dial in" another carb in my life.
EDIT:
Jesus, just re-read your OP. So you have a new pipe, top-end and air filter and trying to jet it properly all at the same time? May the lord have mercy on your soul, for Mr Suzuki will not!
I know it's not what you want to hear, but I'm my opinion such tuning efforts are often more of a ball ache than they are worth. All that lovely R&D work by Mr Suzuki thrown out the window  |
| trh71 |
| smegballs |
| trh71 |
| trh71 |
| stevo as b4 |
| smegballs |
 Posted: 22:00 - 07 May 2013 Post subject: |
Might want to take a read of this.
https://www.iwt.com.au/mikunicarb.htm
Apparently some mikuni jets are measured in volume of fuel delivered.
So very roughly speaking....
70/50 = 1.4
A 70cc is going to need 140% more fuel by mass than a 50cc, let's ignore temp changes and shit for now.
62.5*1.4 = 87.5
What complicates things is stuff like derestricted pipes, and air filters and shit which throws all the original estimations way off. I'm by no means a two-stroke tuner, that just to try and get you a rough idea of where you're at.
Gonna be trial and error to get it running well. Played with the needle jet position too?
To be fair my mates, TS50 never idled without revving its tits off, and was generally pretty shite. My DT50 was the far superior machine
Good luck. |
| trh71 |
 Posted: 19:01 - 08 May 2013 Post subject: |
Thanks
Well going off that, without the K&N on, as it was (50cc), with the Dep exhaust on, it was running a 95 main jet, so 95X1.4=133 which makes sense, as it has been getting better the bigger I go.
What about the pilot jet, what dose it do? Tick over?
The only other thing is OIL, if I'm putting this much more fuel in I better turn the oil pump up!
Just taken it for a run, 42mph, it ran well, plug colour good.
I'll get some bigger jets tomorrow and see if that sorts out the starting and tick over probs. |
| smegballs |
 Posted: 19:53 - 08 May 2013 Post subject: |
| trh71 |
| bladerunner |
| trh71 |
| trh71 |
| trh71 |
| bladerunner |
| trh71 |
| bladerunner |
| trh71 |
 Posted: 21:31 - 18 May 2013 Post subject: |
OK its really doing my head in now!!
I must've tried every combination of main/pilot jet and needle height, but its still popping back through the carb. Worse lower I go.
It runs best at 115 main 17.5 pilot, needle clip down one notch. But it still pops at 7-8k??
What the hell is up?  |
| smegballs |
| bladerunner |
| trh71 |
 Posted: 10:10 - 20 May 2013 Post subject: |
I'm a little red faced this morning
I pulled it in bits again last night, how I never noticed it when I put it on, it's in need of a rebore and oversized piston, well sloppy!
So that's where all my pressure has been going and that's why it's been popping back through the carb! No bloody wonder I couldn't get it tuned in!! What a plonker I feel
I'll let you know how I get on |
| bladerunner |
The last post was made 13 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
