New brake pads - low speed grind
garth
PostPosted: 20:27 - 07 May 2013    Post subject: New brake pads - low speed grind Reply with quote
02 gsxr600
Sbs road/race sintered pads
Just fitted new pads. Discs are good. High speed braking is fine, lots of power. Low speed braking it judders and grinds. Pistons and seals are good.
Part of the bedding in process?
Any ideas?
CaNsA
PostPosted: 20:30 - 07 May 2013    Post subject: Reply with quote
Yeppers, bedding in.
Walloper
PostPosted: 21:14 - 07 May 2013    Post subject: Reply with quote
Drill out the vent holes in the discs.
They fill with brake material and shit which can produce the squeal you mention.
I don't think new pads actually 'bed-in' that much. They only have to wear the shine off.
I've removed new pads after about 100 miles and not really noticed much 'bed-in'.
Brake cleaner on the discs too.
Drilling out the holes is a Main Dealer fix/advice BTW
garth
PostPosted: 08:49 - 08 May 2013    Post subject: Reply with quote
The vent holes in the discs are fine, all clear. Discs have very little wear, aren't grooved etc.
Just ridden to work and it's still doing the same thing, done about 50 miles now.
Almost feels as though the pads are loose in the calipers, or the actual calipers are loose (I've checked, everything is as it should be).
The pistons are all equally protruding.
I'm baffled! I'm even going to check my head bearings this evening although they feel fine too.
Walloper
PostPosted: 15:35 - 08 May 2013    Post subject: Reply with quote
Not to harp on..
I thought the vents in my discs were clear until I went at them with a 7mm drill bit. There may only be a small amount of crud baked on.
Won't hurt to try if you have the time/tools.
It's either that or maybe something between the calliper mounting faces and forks or the anti-squeal shims behind the pads.
It takes very little shit for the vibration from brake pads to be transferred into the forks and resonate to an audible racket.
Very Happy
garth
PostPosted: 15:39 - 08 May 2013    Post subject: Reply with quote
I'll give it a go and I will also bleed them through and check the head bearings. The front wheel bearings are new so it can't be that.
evoboy
PostPosted: 01:07 - 09 May 2013    Post subject: Reply with quote
Ive had this happen before, but it cleared itself up as the pads bedded in.
EBC Sintered in a 2000 zx6r.
APT Motorcycles
The last post was made 13 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 56.42 Kb
