Mounting new number plate
James83
PostPosted: 10:31 - 08 May 2013    Post subject: Mounting new number plate Reply with quote
Got a new number plate, doesn’t have pre-drilled mounting holes. Is there a standard size mounting hole, or do I just eyeball it and redrill if the holes not big enough?
Also, I assume I just pop it in place, put a pencil mark where the hole needs to be? No special regs about where the holes have to be (Other than not through the letters)? Don’t want to go to the trouble of getting a legal plate only to get done because of some stupid rule about how I’ve mounted it 
Aff
PostPosted: 10:42 - 08 May 2013    Post subject: Re: Mounting new number plate Reply with quote
If you've bought the same size numberplate just line it up with the holes from the last, otherwise just eyeball it.
AFAIK no regs on positioning apart from obstructing letters.
Electric Bike Project
cluderayr
PostPosted: 10:43 - 08 May 2013    Post subject: Reply with quote
I would position the plate and use a marker pen on the rear to mark the holes. Fix masking tape first to stop the drill bit slipping. Drill a small pilot hole then larger one to the size of the plastic bolt. Drill through the back of the plate to avoid damaging the laminate on the front. Try to avoid going through letters if possible but i dont think a traffic officer has ever got in a twist over that one. You see it all the time.
Rich
map
Mr Calendar
PostPosted: 10:46 - 08 May 2013    Post subject: Reply with quote
Cover with tape first where you want the holes. This is as drilling may crack the plastic or the drill might slip. IIRC last time I drilled a plate I used a wood drill (the ones with the spike so you make a pilot hole first) on a slow setting.
The holes should not obstruct the letters. Just make sure you use the right coloured plastic/nylon bolts. They should give you a clue what size holes you need. I mention as for 5 years I had a bolt in one of mine then one picky MOT tester said that was wrong.
The last post was made 13 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 41.17 Kb
