Any 2 stroke experts around please?
PostPosted: 19:52 - 08 May 2013    Post subject: Any 2 stroke experts around please? Reply with quote
Hi. I've got a elderly Yamaha Yb100, as a project. It's in a pretty grotty state, and its more a nostalgia driven thing than a genuine good idea. I was amazed when I connected it to a small header tank of fuel with the ease it ran, and ran well, ticking over like a sewing machine, pulling as well as I'd expect, stopping on the key, restarting first or second kick. . Then it stopped, and hasn't run since.
Ive checked the spark, which is very good. I've checked the fuel pipe, and checked the carb. I whipped the plug out and squirted fuel down the hole, then replaced the plug, and on kicking it over it fired then stopped, presumably as it used the fuel in the cylinder. Figuring it to be a carb snag, I've had the carb in bits looking for grime and dirt, found none and rebuilt it. Still nothing.
Had I not had it running I'd have lost my patience by now and stripped it for spares, but I've heard it run, and actually ridden the thing. It was run on premix, as the oil tank is disconnected at present.
Thanks,
Ian.
Timmeh
PostPosted: 19:54 - 08 May 2013    Post subject: Reply with quote
are you sure you're getting a spark?
1198
PostPosted: 19:59 - 08 May 2013    Post subject: Reply with quote
With the plug out and resting on the head there's a cracking spark when turned over.
Timmeh
PostPosted: 20:04 - 08 May 2013    Post subject: Reply with quote
hmm... although I will say that just because a plug sparks in the air it might not do so in the head.
Have you done a compression check?
andy_uk
What's the compression like?
When you try to start it with the plug in, is the plug wet when you take it out?
1198
PostPosted: 20:11 - 08 May 2013    Post subject: Reply with quote
The plug looked reasonably wet, yep. Ill try it with a new plug tomorrow. The compression seems ok, admittedly only judging by the effort to kick it over.
27cows
PostPosted: 20:14 - 08 May 2013    Post subject: Reply with quote
It's sparking...but is it sparking at the right time? Have you checked the points? After a long time laid up, it's entirely possible something has gone slightly out of whack. Possibly a loose contact breaker screw.
Ichy
PostPosted: 20:18 - 08 May 2013    Post subject: Reply with quote
remove the air filter and spray easy start in to the carb. If then bike starts then the carb is not supplying fuel. either one of the jets is blocked or the needle valve is sticking. Is there a drain plug on the bottom of the carb you can undo a little to check there is fuel in the bowl?
sidewinder
PostPosted: 20:35 - 08 May 2013    Post subject: Reply with quote
fuel mixture ratio right for the bike?
The last post was made 13 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.21 - MySQL Queries: 15 - Page Size: 59.55 Kb
