Squeaky breaks
David072
PostPosted: 21:13 - 09 May 2013    Post subject: Squeaky breaks Reply with quote
Hi guys
Had the rear brake shoes replaced in my YBR125 and now they're a squeaky. Is this normal when you get new brake shoes put in?
Anyway to get rid of it or do they just need to be bedded in?
Cheers!
David
Islander
PostPosted: 21:26 - 09 May 2013    Post subject: Reply with quote
Squeaking in drum brakes is usually caused by either an accumulation of dust in the drum or the inner surface of the drum becoming glazed.
You could just give the shoes a chance to bed in and see if the problem goes away. If it doesn't, whip the wheel off and clean the drum out. If it isn't dusty have a look at the surface and check whether it's glazed. If it is, use some fine wet and dry to remove the glaze.
The last post was made 13 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 31.2 Kb
