| koolio |
 koolio Spanner Monkey
| Islander |
 Islander World Chat Champion
| koolio |
 Posted: 14:53 - 10 May 2013 Post subject: |
Herein lies the problem:
The red line is the diameter of the inside of the headstock tube.
And the blue line shows the inner edge (roughly the diameter) of the tapered bearing cup.
There is no way I can see to push out the bearing cup as its diameter is greater than that of the headstock tube, is there such a tool that can deal with this?
https://i747.photobucket.com/albums/xx115/accjnt/Bearing/IMG_3659_zps71c333c0.jpg |
| Aff |
 Aff World Chat Champion
 Posted: 15:00 - 10 May 2013 Post subject: |
Cut a groove in it, then hit the groove with a chisel, should relieve the pressure so you can pry it out.
Works really well on external bearings, but I have also removed internal bearin races with this method fairly successfully. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| stirlinggaz |
 Posted: 16:45 - 10 May 2013 Post subject: |
| Aff wrote: | Cut a groove in it, then hit the groove with a chisel, should relieve the pressure so you can pry it out.
Works really well on external bearings, but I have also removed internal bearin races with this method fairly successfully. |
hi,
unless im not reading this correctly, the op wants to remove the bearing & then re-use it, no?
never done this with bearings before, just tyres,plastic bits etc (& covered up all threaded parts with old bolts) when sending off frames/forks & other bits to be powder-coated.
i also would be interested in any tool that can remove tapered bearings (like those in headstocks) like these https://www.ebay.co.uk/itm/Headstock-Bearing-Set-Suzuki-RG125-UN-92-95-/221014590536?pt=UK_Motorcycle_Parts_13&hash=item33757f0448
due to price & unavailability of some. (as in older bikes which have cups & ball bearings & i want to replace with the above type)
i guess it would be some sort of slide hammer/bearing puller?
tbh, never really looked into it as its the kind of job you do once in a blue moon & the cost of any tool would mean its not a worthwhile investment?
cheers,
GAZ |
| Aff |
| koolio |
| Aff |
 Posted: 17:34 - 10 May 2013 Post subject: |
So does the cup need to be removed for any of the modifications? Or just for the powder coating?
If it is just the powder coating then I wouldn't bother, as you will have to plug the hole anyway so may as well just make a plug to cover the cup as well.
If you need to remove for modifications and aren't worried about paint, etc. I imagine it will come out with some heat fairly easily. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
| koolio |
 Posted: 17:49 - 10 May 2013 Post subject: |
Well really just the powder coating. But I still would like to know how to do it properly without damaging the cone if its possible.
Removing the standard OEM ball bearing cones with causing damage is fairly easy with the right puller, it was a complete oversight for me when I installed the cones for the tapered bearings  |
| Grubby |
 Grubby Spanner Monkey
 Posted: 18:00 - 10 May 2013 Post subject: |
You can safely leave the cup in for powder coating. Degrease it thoroughly & mask it off well & you should be ok. If you try to remove it chances are you'll bugger it. When I have to remove bearing cups like that I use a die grinder & burr to cut a groove in it to release the pressure. They come out easy then.  ____________________ I am me & you are he & we are all together. See how they run like pigs from a gun! |
| yen_powell |
| koolio |
| yen_powell |
| koolio |
| Grubby |
 Posted: 19:47 - 21 May 2013 Post subject: |
The last post was made 13 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
