1990 GPZ No Power to ignition (need help locating main fuse)
newbiker1
PostPosted: 22:07 - 11 May 2013    Post subject: 1990 GPZ No Power to ignition (need help locating main fuse) Reply with quote
Hi guys,
i recently bought a gpz that had been stood fora couple of years. I rode home on the motorway doing 80 and it overheated and melted the sparkplugs.
i tried to start it, but because the spark plug cap melted it just wasnt catching.
when getting home, the battery was flat but had enough power for headlights. i put the battery on trickle charger for some hours, reconected, and now im not getting any power at all to the bike.....not neatural light, headlight, nothing.
I checked the fuse box and the 20amp is blown (which i have ordered more on ebay). but im thinking it could be the 30 amp main fuse aswell possibly, but have trired for approx 2 hours to locate to no avail.
what is the 20amp fuse used for in the bike, and could replacing that alone give me back power?
another thing, ive also tried jump starting off a car, and push & bump start, with not so much as a turnover.
the carbs have now been stripped and cleaned, so just need to located this 30amp and get her running again.
pictures would help but realise not many people own this particular bike anymore, but im hoping most gpzs have same location of main fuse.
temeluchus
PostPosted: 22:32 - 11 May 2013    Post subject: Reply with quote
GPz what? there are few different models called GPz, 900, 600, 500, 500 and probs a few more in 1990.
J.M.
PostPosted: 23:03 - 11 May 2013    Post subject: Reply with quote
20A fuse may be the ignition fuse, so effectively you can't turn the bike on hence no lights. I may have a diagram if you tell me the year/model... I have loads of workshop manuals.
2004 R1 & 2018 XSR900
newbiker1
PostPosted: 23:25 - 11 May 2013    Post subject: Reply with quote
gpz 305 sorry
PostPosted: 23:34 - 11 May 2013    Post subject: Reply with quote
On top of the starter solenoid. Follow the big fat wire from the battery positive.
BUT
If it overheated enough to melt a plugcap doing 80mph, you have more serious problems. Probably running lean as hell but could also be a serious oilfeed issue.
You do know about these bikes and their propensity for blowing up, seizing, melting or otherwise shitting themselves in a costly and terminal manner right?
It may already have done so.
Engine 1:
https://i48.photobucket.com/albums/f216/stinkwheel/305/Image010.jpg
Engine 2:
https://i48.photobucket.com/albums/f216/stinkwheel/305/Image031.jpg
Engine 1 again following crank-up rebuild.:
https://i48.photobucket.com/albums/f216/stinkwheel/305/Image079.jpg
I gave up taking photos after engine 3 seized.
The last post was made 13 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 44.58 Kb
