Honda CBR 125 Rear Brake Light stuck on
RockandGrohl
PostPosted: 13:30 - 12 May 2013    Post subject: Honda CBR 125 Rear Brake Light stuck on Reply with quote
Hello, so I am having a minor problem with my bike, the rear brake light is constantly on. If I pull the lever or press the foot brake, the light does not change. I have looked it up and seen that it is caused by the rear brake switch sticking, and I just have to adjust a bolt. Which bolt? Haha. Can someone provide a picture as I can see a bunch of nuts and bolts that seem to be connected to the rear brake switch.
Thank you!
AyrshireBiker
PostPosted: 13:33 - 12 May 2013    Post subject: Reply with quote
Try a good bit of WD40 first and press / release the brake pedal a few times and see if it frees off. Sometimes they get jammed up with road muck.
RockandGrohl
PostPosted: 13:43 - 12 May 2013    Post subject: Reply with quote
After doing some more investigation -
The front brake makes a very slight click sound, if I pull the brake the light stays on, I have to manually push the lever back to it's original position to make the light go off.
The rear brake does nothing to the light until it is almost fully depressed, so light braking will not fire the lights, which is pretty bad.
So I need to make the front brake lever spring back to it's original position (it feels quite loose and wobbly) and also make the rear brake light more sensitive.
The rear brake light is on all the time unless I push the front brake lever back in to place.
The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 35.72 Kb
