need help with aprilia rs 125 122 engine
gav1
PostPosted: 17:14 - 12 May 2013    Post subject: need help with aprilia rs 125 122 engine Reply with quote
hi im new to this just wont to know if the aprilia rs 125 122 engine parts is the same on all years i need to change the clutch cover clutch arm gear selector in the engine ang clutch cable my bike is a 1994 but mite not be the same engine need help please
andy_uk
PostPosted: 18:12 - 12 May 2013    Post subject: Reply with quote
I can't say 100% yes, but when I rebuilt mine I just ordered parts for the 122 without specifying the year (bearings, gaskets etc) and there was no problem.
//edited to add :
Just looked on ultimateparts.net and the clutch cover is the same for all models from 1999-2009
gav1
PostPosted: 18:15 - 12 May 2013    Post subject: Reply with quote
thank you andy
gav1
PostPosted: 18:22 - 12 May 2013    Post subject: Reply with quote
so the clutch cover before 1999 are not the same as a 1994 is there anyway you can tell the year of the parts i need
stirlinggaz
PostPosted: 18:51 - 12 May 2013    Post subject: Reply with quote
hi,
you sure you have a 122 engine in it?
if its a 1994 bike it should be a 123 engine & afaik the the clutch covers are different,
cheers,
GAZ
gav1
PostPosted: 18:55 - 12 May 2013    Post subject: Reply with quote
how can i tell iv been looking at bits on ebay and it looks like a 122
gav1
PostPosted: 19:02 - 12 May 2013    Post subject: Reply with quote
iv had a look and the clutch cable goes in side the clutch cover on to the arm witch works on 3 bearings does this help thanks gav
stirlinggaz
PostPosted: 19:54 - 12 May 2013    Post subject: Reply with quote
Hi,
have a look on the cylinder, it should be a rotax 123 or mitaka 123 if its been changed.
the model number is quite easy to work out.
if its got a 122 engine in it, then its been replaced at some point,
have a look here https://www.apriliapartsonline.co.uk/index.php/motorcycles-up-to-250cc/rs-125/rs-125-1995-1995.html
cheers,
GAZ
ps ; if you cba to look its here https://www.apriliapartsonline.co.uk/index.php/motorcycles-up-to-250cc/rs-125/rs-125-1995-1995/mix-oil.html
gav1
PostPosted: 20:14 - 12 May 2013    Post subject: Reply with quote
just had a look its only got aprilia on it can i tell with the clutch cover where will the find the model number thanks
stirlinggaz
PostPosted: 21:07 - 12 May 2013    Post subject: Reply with quote
you sure it says aprilia on the cylinder?
usually says "aprilia" on the clutch cover (the plastic bit) but will have 122 or 123 on the cylinder (the top bit, metal) with "rotax" being the company who built it. or mitaka if its been replaced.
its all in the wsm or on parts diagrams as listed.
cheers,
GAZ
The last post was made 12 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 60.9 Kb
