Headlight cutting bike out?
rachaelmcl
PostPosted: 12:27 - 13 May 2013    Post subject: Headlight cutting bike out? Reply with quote
Hi. I've recently got my Yamaha ybr 125 '06 back on the road after an accident last year. On the way home from my MOT the bike cut out. I started it back up and now every time I switch the headlight on the bike instantly cuts out. After the crash I fitted a new headlight, but it worked fine for the first week or so. I'm not too good with bikes, my boyfriend usually fixes everything, but this is baffling him too. We've checked the fuses and all the connections and wiring and everything seems fine, but neither of us are too good with electrics. Any ideas? Please help.
Formerly known as
P.
PostPosted: 12:30 - 13 May 2013    Post subject: Reply with quote
Check wiring around the headstock. Sounds like something earthing out.
Islander
PostPosted: 12:42 - 13 May 2013    Post subject: Reply with quote
What Paddy said - check the loom where it passes under the tank and out to the headlight as well - it may have either chafed through or been physically damaged.
rachaelmcl
We had a good look at all the wiring yesterday and everything seemed okay, but I'll have another fiddle. I should probably mention that the bike only starts with the kick start, since I got it the electric start has never worked, and other parts such as indicators, the horn and the brake light have done this before, then randomly started to work again. People suggested a new regulator, or an entire new wiring loom, but I'm hoping it's just something simple. Also, oddly, when the headlight was working the higher the revs the dimmer the light would go, and when indicating the headlight would flash on and off. Everyone I've spoken to has been completely baffled, it's just problem after problem.
Formerly known as
P.
PostPosted: 13:09 - 13 May 2013    Post subject: Reply with quote
Yeah... sounds like the wiring has been kinda bodged back on.
Would get the loom clear to inspect, easy to remove various bits of that bike so would remove the loom, label it and check all wires.
The last post was made 12 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 15 - Page Size: 42.24 Kb
