| Knisis |
 Knisis Nova Slayer
| Jammy-G |
 Jammy-G Banned
 Posted: 20:23 - 28 Nov 2004 Post subject: |
Hmm sounds like what happened to mine.
I am not 100% here but It might have stuttured when opening it up because the increase of revvs would 'blow out' the spark, causing it to misfire. Change the plug if you havn't already.
Has it only just started doing this? After my accident, my bike would die idling without the choke out even when the bike was warm. I just ran it for a bit and it seemed to sort itself out.
My advice - new plug  ____________________ RooRoo: just like the time i stuck my finger up my arse with no lube at all and she didnt talk to me for hours |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 20:24 - 28 Nov 2004 Post subject: |
Does the lumpiness only occur past about 3/4 throttle, and not below that?
If it's only affecting part of your throttle range, it's likely that the high end jet is a bit blocked.
There are multiple jets in your carburettor for different throttle positions, as the vacuum in the carburettor is moved around it as you change the throttle, so it sucks fuel at different rates through each one.
Basically, remove the carburettor and give it a good clean out, especially including blowing compressed air through all the jets. ____________________ I must not be a troll...
Mmmm, Guinness
| stevo as b4 |
 Posted: 21:20 - 28 Nov 2004 Post subject: |
That is a problem that can occur on the CG125 also. It does sound more fuel related than anything, but do the usual checks/maintanece items first.
Check airfilter,sparkplug,HT lead, plug cap, timing etc. strip and clean the carb and all the jets. Make sure you dont have stale fuel, and that there are no kinks or blockages in the fuel line, filters, or tap that may cause fuel starvation. If everything else is ok, it could be a problem with the accelerator pump on the carb, either a blocked jet etc, or badly adjusted. |
| binge |
 binge Emo Kiddy
 Posted: 23:36 - 28 Nov 2004 Post subject: |
I had that problem with my Speedfight. And I found out that it was flooding out with air...
It is like if you buy a standard restricted scooter, and try to ride it without the air box on (Just an open carb) It just dies out when on full throttel...
I have a question tho.
When I go to start my scooter from cold (Weather its 30*F or weather its 100*F) I have to use the choke to start my scooter.
Even if I just put it on, Let it fire up then turn it off. The choke HAS to be on for the bike to fire ...
Any suggestions???
<|Binge|> |
| pipnet11 |
 pipnet11 Brolly Dolly
| Knisis |
 Knisis Nova Slayer
| Knisis |
 Knisis Nova Slayer
| mchaggis |
 Posted: 00:17 - 07 Dec 2004 Post subject: |
Yay, some feedback from a Workshop user and I was right.  ____________________ I must not be a troll...
Mmmm, Guinness
The last post was made 21 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
