Ballast Resistor - what now?
mudcow007
PostPosted: 22:50 - 13 May 2013    Post subject: Ballast Resistor - what now? Reply with quote
Right just went for a jaunt on my trusty CG, it started to go dark so switched on my headlight a split second later....it goes pop
switch to high beam...pop
just been reading through older threads, an people mention a ballast resistor fitted behind the headlight.
i aint got one of these or even ever seen one.
anyone know how its wired, an could fitting one cure all my issues?
much love
thanks
Copycat73
PostPosted: 08:32 - 14 May 2013    Post subject: Reply with quote
have you put a volt meter across the battery terminals wit the engine running ?
caveat emptor
mudcow007
PostPosted: 09:34 - 14 May 2013    Post subject: Reply with quote
i have checked this in the past but i will check again at lunch time
what should i be getting at idle/ running fast?
thanks
Copycat73
PostPosted: 15:01 - 14 May 2013    Post subject: Reply with quote
your lookin for 13.8volts but but 10% out either way is ok
caveat emptor
mudcow007
PostPosted: 15:26 - 14 May 2013    Post subject: Reply with quote
is that at high revs or all through the range?
Aff
PostPosted: 15:29 - 14 May 2013    Post subject: Reply with quote
Will probably peak about 14.5.
As long as your getting about 12.6 when charged, 13.5 when idling and about 14 when revving, your charging system is most likely fine.
Electric Bike Project
Copycat73
PostPosted: 16:02 - 14 May 2013    Post subject: Reply with quote
12.4v - 15.1v at any revs.
caveat emptor
mudcow007
PostPosted: 08:55 - 15 May 2013    Post subject: Reply with quote
right
at the battery im getting 12.6 with bike turned off
13.9 running (throttle 50%)
any ideas?
mudcow007
PostPosted: 16:42 - 15 May 2013    Post subject: Reply with quote
i have checked the holder for shakeyness too, it seems solid in the headlight, i will check the voltages at the bulb tonight
its gettign on my tits, i suppose i can just use it in the day time though....
Copycat73
PostPosted: 20:55 - 15 May 2013    Post subject: Reply with quote
them voltage readings are fine....
you haven't poped any other bulbs... so..
hang the head light by its wires... put in a new bulb... try again switchin the light on... if all works ok... get a magnifying glass and start lookin for a short circuit.
have you fitted anything new or adjusted owt in that area ?
what writin is on the dead bulb ?
caveat emptor
The last post was made 13 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.99 - MySQL Queries: 13 - Page Size: 63.59 Kb
