chain snapped
mark111
PostPosted: 22:23 - 14 May 2013    Post subject: chain snapped Reply with quote
Hi guys , well at the title says , was out a wee run and my chain snapped , luckily was going snow so no crash or damage , my question is , is this an easy repair as obviously i had to leave the bike where it was and would like it repaired as soon a possible , is this something can be done while its still sitting on the road or does it need the back wheel to come off , "dont have a rear wheel stand " , thanks for any reply's , mark
at least it was at the garrion bridge in lanarkshire so had a nice view while i sat there swearing at the chain , lol
Ariel Badger
PostPosted: 22:28 - 14 May 2013    Post subject: Reply with quote
The title says very little, it would help if you told us what bike it is.
Turkish
PostPosted: 22:44 - 14 May 2013    Post subject: Reply with quote
Depends on other damage.
Best case scenario, get a split-link chain and you could probably do it at the road-side even without a stand - it would be hard but not impossible.
Worse case, fucked sprockets, crankcase, and so on...
ZX-6R G2
CBR125R RW6
Walloper
PostPosted: 22:45 - 14 May 2013    Post subject: Reply with quote
An 'Easy' repair is if you can get a split link to suit the pitch of the chain and fit that to the fooked chain and nurse the hoowur home.
Depends where you are on the planet. There is a good bike shop not far (Not 100 miles) in Airdrie called Girders. If you give them a call they 'may' be able to help you with recovery and repair. Good guys in there.
01236 753995.
Bikes are a bastirt. I honestly don't know why anyone bothers with them. Cool
mark111
PostPosted: 00:08 - 15 May 2013    Post subject: Reply with quote
cheers guys , bike is a Suzuki gz 125 , no damage as far as i could see , chain just snapped and rolled off the sprockets on to the road ,
So instead of getting a link would a whole new chain be doable at the side of the road , cheers , mark
Ed Case
PostPosted: 00:09 - 15 May 2013    Post subject: Reply with quote
Chains rarely 'snap' without good reason, they're usually phukt when that happens through either use beyond their useful life (worn to death) or poorly maintained or adjusted. You'd be surprised in how few miles a chain can be ruined in. If a chain is run too slack the bottom run can 'slap' up and down which can 'hook' the sprocket teeth in no time at all buggering both sprockets.
bridgedino
PostPosted: 00:47 - 15 May 2013    Post subject: Reply with quote
So your saying your bike has been left, un guarded at the garrion bridge in lanarkshire. A Suzuki GZ 125 you say.
Just off for a run in my van...
dafty
Walloper
PostPosted: 00:53 - 15 May 2013    Post subject: Reply with quote
dafty
Awe typical fae a Fifer... Rolling Eyes
Commuter_Tim
PostPosted: 01:42 - 15 May 2013    Post subject: Reply with quote
dafty
The man has a point, its a bit late for editing posts now, but you may want to just pay to get it picked up asap, you have theft insurance?
I ride a Bandit 600... badly.
trevor saxe-coburg-gotha
PostPosted: 05:08 - 15 May 2013    Post subject: Reply with quote
Unless someone's fitted an after market heavy duty O or X job I reckon that chain's a split link so actually you might be able to sort this without recovery. If you can get a link, or even a whole new chain, remember to fit it such that the two prongs of the retaining clip face rearwards i.e. in the opposite direction to that which the chain moves.
J.M.
PostPosted: 08:56 - 15 May 2013    Post subject: Reply with quote
Buy £15 RK split link chain on eBay. Go back to bike and fit it. May need to remove front sprocket cover.
Tools required:
- whatever you need to remove front sprocket cover
- pliers
Then keep on top of chain maintenance or that one will snap too.
2004 R1 & 2018 XSR900
mark111
PostPosted: 11:17 - 15 May 2013    Post subject: Reply with quote
cheers guys , i will get a new chain and see if i can pop it on , the old one looked ok , well oiled and no seized links i could find , it was needing adjusted quite a few times though so i guess it was at the end of its life
Brick_Top
PostPosted: 11:21 - 15 May 2013    Post subject: Reply with quote
Hope the bike is well secured.
If it was mine I'd be looking at getting someone in a van to get it, before a thief does.
mark111
PostPosted: 11:31 - 15 May 2013    Post subject: Reply with quote
yeah , bikes ok , a nice old lady let me park it chained up in her back garden
PostPosted: 12:20 - 15 May 2013    Post subject: Reply with quote
Oh yeah?? Don't trust the old wifey witch. She'll have got a new DID heavy duty on it and be hoiking mingers on the pub car park this very night, if I'm any judge. And mark my words young man, I am. I am.
PostPosted: 12:23 - 15 May 2013    Post subject: Reply with quote
As no one else seems to have mentioned it, are you sure it wasn't just the split link that has failed?
Scotsman37
PostPosted: 13:01 - 15 May 2013    Post subject: Reply with quote
Good point because it takes a hell of a lot to break one of those unless it was a manufacturing failure of the chain or someone prior to you owning the bike did substandard job of linking the chain together properly?
This is where it's good to have insurance with break down/home recovery which would have brought you and your bike home rather trying to make your way back there in attempt to relink the chain!
Walloper
PostPosted: 13:27 - 15 May 2013    Post subject: Reply with quote
I think that has already been attended to.
dafty
mark111
PostPosted: 14:35 - 16 May 2013    Post subject: Reply with quote
another question guys , i ordered a DID chain , will this come the correct size or will i have to buy a chain splitter and take some links out , or can it be done without a chain splitter , cheers ,
Walloper
PostPosted: 14:41 - 16 May 2013    Post subject: Reply with quote
It is possible to order the exact No. of links for your bike or just a length you have to push a pin out of.
If you have the old chain or a manual it will tell you how many links is spec.
mark111
PostPosted: 15:23 - 16 May 2013    Post subject: Reply with quote
cheers for the reply m8 , i just ordered this one so i hope it fkin fits , lol https://www.motorcycle-road-and-race.co.uk/chain-and-sprocket-kit-suzuki-gz-125-yk1-marauder-99-05-economy-p-405324.html
Ed Case
PostPosted: 19:31 - 16 May 2013    Post subject: Reply with quote
Should fill the bill nicely and be the correct number of links.
The last post was made 13 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 110.64 Kb
