All 4 indicators stopped working
Bandit6
PostPosted: 15:02 - 15 May 2013    Post subject: All 4 indicators stopped working Reply with quote
No green light on board for indicating, relay is making click, front light is ok, tail one ok. Fuse I put new spare, but it was not necessery. Can it be relay even its clicking sound.
At beggining there was very light green light on board visible, but now not green light showing indicators.
its honda Anf 125, thanks for advice
PostPosted: 15:32 - 15 May 2013    Post subject: Reply with quote
Yes, the relay can still click even if it isn't making the contacts properly.
If neither left or right are working and the bulbs are ok it has to be part of the common circuit.
https://img5.imageshack.us/img5/7839/indicator.jpg
So really can only be supply (fuse) relay or switch (very unlikely). Do you have a multimeter? You can get really cheap ones that will save you pounds diagnosing what is wrong rather than buying each bit and changing it to find the fault.
Triumph Trophy Launch Edition
Bandit6
PostPosted: 16:27 - 15 May 2013    Post subject: Reply with quote
Firstly, thank you for your time reading and writing your point. It must be that flasher (ignition relay) or switcher on handlebar. I have already ordered new relay. I couldnt find it, finally I found it, its stuck under front board. I dont want go to garage, its not so big deal not to be able to do it myself, even I am not so technicall type.
I know its some simple stuff and belief that its matter of couple of minutes for handly man in garages, but I got feeling they sometime just doing big things from piece of cake.
Bandit6
PostPosted: 22:49 - 18 May 2013    Post subject: Reply with quote
It was relay, I replaced with new one, but there is still small problem. Indicators flashing, but a little bit slower than probably should. I still didnt do anything about it, but if you got ideal how to make them to flash in normal rythmus then I would appreciate. Thank you
smegballs
PostPosted: 23:39 - 18 May 2013    Post subject: Reply with quote
How slow is slow? As long as they are between 60 and 120 flash per min you are all good in the hood.
Bandit6
PostPosted: 20:32 - 19 May 2013    Post subject: Reply with quote
Slow is 60 flashes per minute. Before it was considerable quicker.
The last post was made 13 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 48.5 Kb
