Aprilia RS125 2008, How much Pro boost?
gedi1305
PostPosted: 19:14 - 15 May 2013    Post subject: Aprilia RS125 2008, How much Pro boost? Reply with quote
Hello i own a aprilia rs125 2008 and i have bought some pro boost but i do not know how much to put in
if any one knows, you'd be a great help
thanks
Quote Me Happy
PostPosted: 19:17 - 15 May 2013    Post subject: Reply with quote
Hmmm, it depends. What colour powerband do you have?
gedi1305
PostPosted: 19:19 - 15 May 2013    Post subject: Reply with quote
what do you mean what colour power band?
Quote Me Happy
PostPosted: 19:21 - 15 May 2013    Post subject: Reply with quote
I was being facetious, ignore me.
What is "Pro Boost"? Octane booster? Don't bother would be my advice.
gedi1305
PostPosted: 19:24 - 15 May 2013    Post subject: Reply with quote
Pro boost just helps to your engine running clean gets rid of carbon left in the engine
but i havent used it before and i was just wondering how much to use
Quote Me Happy
PostPosted: 19:30 - 15 May 2013    Post subject: Reply with quote
TBH most of these "magic" fuel additives do little good, if any at all with the potential to be harmful.
If I was going to try something similar I'd run a couple of tanks of premium petrol through the bike which supposedly have extra detergents in them to clean the engine.
But in reality, I wouldn't even bother doing that.
gedi1305
PostPosted: 19:34 - 15 May 2013    Post subject: Reply with quote
Yeah i might mate
the garage sells super unleaded so i might use that instead of the standard stuff
Quote Me Happy
PostPosted: 19:36 - 15 May 2013    Post subject: Reply with quote
I'd save the money you could spend on fancy fuels and just put it towards some more decent two stroke oil.
gedi1305
PostPosted: 19:40 - 15 May 2013    Post subject: Reply with quote
i do use the silkolene stuff so its a good brand
bladerunner
PostPosted: 23:18 - 15 May 2013    Post subject: Reply with quote
If its silkolene pro boost then use between 1%and 3% or about a teaspoons worth for every 5 litres of fuel you put in the tank. It is safe for 2 strokes unlike most of the additives which break down the oil in the top end and crank....but if you do use it...I wouldn't bother using it all the time as a booster if that was your idea?
PostPosted: 23:36 - 15 May 2013    Post subject: Reply with quote
Take one already grenade like 2 stroke.
Add chemical.
£450 to PJME.
Or... you could just fill it with normal fuel, ride it properly and the carbon shall be built up so slowly you'll never know.
duzzer
PostPosted: 02:08 - 16 May 2013    Post subject: Reply with quote
FFS dont do it, if you put any of that in ur fuel expect it to seize up,,,
2T's ar highly tuned engines and if you mix that pup with ur fuel you make it run lean, it will take a small amount of % from ur air fuel mix making it run hot then seize
also if you bike is jetted to take 95 octane fuel dont use no special or premium fuel as this will be bad to, standerd fuel with good semi-simthetic oil and the rs125 last,,, run them on crap oil or all singing n dancing power or economy fuel and thay dont like it you'll be doing a engine re-billd be for carbon deposit billd up
ps silkolene is a fantastic oil to use on the rs but silkolene pro boost err no
The last post was made 13 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 69.84 Kb
