suzuki sv650s 2008 sticking rear brake
burnleyman188...
PostPosted: 02:47 - 16 May 2013    Post subject: suzuki sv650s 2008 sticking rear brake Reply with quote
When i apply my rear brake the pedal with press down it will work fine and the brake will apply but the lever will not release.
any ideas what the problem is?
cheers
James
J.Cook
duzzer
PostPosted: 02:50 - 16 May 2013    Post subject: Reply with quote
at a gess,, master cylinder does the bike move freely in N after the brake been pressed
WindyMiller
PostPosted: 09:18 - 16 May 2013    Post subject: Reply with quote
I had that about a month ago, had to release the rear brake by hooking my foot under the pedal and lifting it up. Apparently, the caliper was so full of salt corrosion it was pushing the seals out. Had the calipers taken apart, cleaned out, new seals and they were fine.
YBR125 SV650S Triumph Sprint ST 1050
Fizzer Thou
PostPosted: 09:36 - 16 May 2013    Post subject: Reply with quote
It could be any part of the back brake system and the master cylinder would be worth investigating.But the back brake pivot for the pedal/lever could also be the culprit.Sometimes there is a plain bush in the pivot that is plastic.Once this starts to wear it causes the lever to move around quite a bit.In the past I have used a phosphur-bronze bush to remedy that sort of situation.
Always have a 'Plan B'
The last post was made 13 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 39.45 Kb
