Handlebar wobble, what do you reckon?
donniemateno
PostPosted: 20:31 - 16 May 2013    Post subject: Handlebar wobble, what do you reckon? Reply with quote
After seeking advice ive been told id get lots of opinions if I post in the workshop Smile
I picked up a CBR600 and its all good but have come across a small issue. When I ride the bike above 40 MPG roughly I get a SMALL amount of handle bar wobble. as I speed up you can feel in in the bars. below 40 its fine
After research I have found it can be :
a unevenly worn tyre
unbalanced wheel
warped disc
or a seized caliper
what do you think it could be? as I would of thought a disc or caliper I would feel at all speeds not just high, Im leaning towards a unbalanced wheel ( as this is the cheapest to get check out too) . however I do have a weight on the wall but this does not mean its balanced
Its also just had an MOT yesterday before I picked it up, so im guessing things such as alignment and seized caliper etc should of been picked up and advised?
any advice appreciated.
Current bike: Honda CBR 600 F3
Previous bikes: Honda XR 125L5 , BMW 800 ST, Honda CB500
Sako
PostPosted: 21:53 - 16 May 2013    Post subject: Reply with quote
Parkinson's.
PostPosted: 22:09 - 16 May 2013    Post subject: Reply with quote
Steering head bearings.
Could also be a rear bearing issue too.
J.M.
PostPosted: 22:13 - 16 May 2013    Post subject: Reply with quote
Checked your tyre pressures?
Incorrect pressures produces notable bar wobble.
2004 R1 & 2018 XSR900
Islander
PostPosted: 23:07 - 16 May 2013    Post subject: Reply with quote
Start with the simple stuff. Tyre pressures and tyre wear. Is the rear wheel correctly aligned?
ginny
PostPosted: 23:15 - 16 May 2013    Post subject: Reply with quote
If its got a topbox, it's that.
donniemateno
PostPosted: 10:01 - 17 May 2013    Post subject: Reply with quote
Thanks to those with helpful replies
i have checkd pressures front eas low only 20 psi i have pumped up still have the issue
the rear tyre is new and fited only wednesday morning
Fizzer Thou
PostPosted: 10:24 - 17 May 2013    Post subject: Reply with quote
I would be thinking headrace bearings as well.These are easily checked.
Did you buy the bike from a dealer/shop that also did the MoT?
If so I would be taking the bike back to the place.
If private purchase did you get a receipt stating 'Sold as seen'?
Always have a 'Plan B'
mysterious_rider
PostPosted: 10:27 - 17 May 2013    Post subject: Reply with quote
To test the headstock bearings, sit on the bike and hold the front brake, push forwards, hard. If you feel clicking this is a bad sign.
Also, put the bike on it's side stand, go to the left of it, pop your foot behind the stand, pull on the frame and get the front end to lift up (so it's weight is on the sidestand) then turn the bars right, and let them drop left of their own accord (gravity) if the movement is notchy, or they stick. You need new bearings.
KAWASAKIIIII
R1stu
Shrek!
PostPosted: 10:31 - 17 May 2013    Post subject: Reply with quote
Really?
My ninja tries to kill me between 40-50mph with tank slappers unless Ive got a death grip on the bars!
Ive got a top box. done everything else here and better but still there so can this be it?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
mysterious_rider
PostPosted: 11:14 - 17 May 2013    Post subject: Reply with quote
R1stu wrote:
Really?
What the hell that should not be happening, Especially if you are only riding sensibly.
Maybe try losing it for a day or something. See if it helps.
KAWASAKIIIII
Fizzer Thou
PostPosted: 11:37 - 17 May 2013    Post subject: Reply with quote
I recollect a motorcycle magazine showing how easy it was to have stability problems with overloaded top boxes and the problem of weight distribution.They placed house bricks in the box and performed a series of acceleration tests.I thought at the time that the rider was crazy,but it was all done under controlled circumstances.
The magazine also did a test with handlebar fairings and showed how they could cause instability problems.
mentalboy
PostPosted: 11:47 - 17 May 2013    Post subject: Reply with quote
Doesn't seem to give the Zed any problems with a top box and all the junk I've stacked in it in the past.
Would incorrect bar ends have this effect - Mine have always had the right ones on but I should imagine that if you removed the stock ones and replaced with lighter/left them off that you'd get some grief.
I'd be surprised if steering head gave that kind of noticeable problem at 40, unless it's proper mullered.
Does sound as though you need to have a quick bearing check on steering/ suspension problems, I'd be starting at the hubs and working inboard if it were me.
+1 for alignment.
Warped discs will pulse through the lever when you use them.
Make mine a Corona.
donniemateno
PostPosted: 13:27 - 17 May 2013    Post subject: Reply with quote
I bought from a dealer sold as seen but it had the mot with no advisories.
Hope theyve not given me a dodgy one!
Islander
PostPosted: 13:30 - 17 May 2013    Post subject: Reply with quote
That's by no means a certainty. They can cause instability if they're overloaded or if they're poorly designed aerodynamically but it's more likely to be a simpler explanation like tyre wear or pressures.
Bar end weights are really intended to damp vibration - I'd be surprised if changing them affected stability.
donniemateno
PostPosted: 13:56 - 17 May 2013    Post subject: Reply with quote
Btw i dont have a topbox
donniemateno
PostPosted: 15:18 - 17 May 2013    Post subject: Reply with quote
I emailed garage and got this as a reply
The bike rode fine and was road tested The rear tyre can effect handling until its bed in Also check the front and rear tyre pressure this will effect handling 30 PSI front and 36 PSI rear other than that check rear wheel alinement through the chain adjusters also could be worth getting the front tyre balanced
mentalboy
PostPosted: 15:38 - 17 May 2013    Post subject: Reply with quote
When you buy 'sold as seen' most garages will have had a quick look over the machine and decided that putting any issues right/ blinging up paint etc will strip the profit from their sale. ie the bike's not worth ( to them) spending time/ parts on it.
If they are hinting at wheel issues I'd be inclined to have a good look at the wheel bearings once you've done what they suggest if that hasn't solved the problem.
I'm always very careful when buying 'sold as seen' as there is usually a good reason why they don't want to sell bike with a warranty, etc. If you find that there is something dangerous on the machine then most places I've dealt with do attend to the parts but I don't know where you stand legally with regards their obligations.
Make mine a Corona.
mudcow007
PostPosted: 15:51 - 17 May 2013    Post subject: Reply with quote
if the bike has been stood for a while on a side stand could that make the front tyre deform causing it to wobble?
im guessing though?!?
ginny
PostPosted: 16:57 - 17 May 2013    Post subject: Reply with quote
No, but its by far the easiest/most black and white problem. And mine does it even when its lightly loaded or empty, but not when there is no topbox.
\game of thrones
It is known.
/game of thrones
ginny
\game of thrones
It is known.
/game of thrones
donniemateno
PostPosted: 19:30 - 17 May 2013    Post subject: Reply with quote
well im going to take to my local garage tomorrow and have the tyres checked for balance tomoz as I tried the suggested apply the brake on the bike and really push on the bike and turning the handle bars no obvious knocks etc
the bike had been sat at the garage for a few months apars and the ownder before hand had only done 1000 miles in 3 years
Fizzer Thou
PostPosted: 21:21 - 17 May 2013    Post subject: Reply with quote
If you are not happy with the bike you can take it back and demand your money be returned,whether they gave you a warranty or not.
Just mention Trading Standards and the Sale of Goods Act
donniemateno
PostPosted: 10:58 - 18 May 2013    Post subject: Reply with quote
took to a garage this morning, brakes and bearing ok, from looking at it he says the rear tyre hasnt been fitted properly as the yellow dot? on the ttyre is the lightest bit of the tyre and should be by the valve not randomly fitted as it is on mine
the front tyre he said he doesnt understand why I have 3 sets of weights on it, so that will need balancing too
PostPosted: 11:01 - 18 May 2013    Post subject: Reply with quote
I have heard that yellow dot/ red dot a few times before but every car that was at the old dealership I worked at ignored this, no one died... So i'm kinda guessing its a load of turd Laughing
The last post was made 13 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 127.19 Kb
