cbf125 problem, head bearing??
LockyUK
PostPosted: 16:55 - 17 May 2013    Post subject: cbf125 problem, head bearing?? Reply with quote
when i brake on the cbf and come to a stop, i can hear and feel a knock from the front end and the steering can be quite, unpredictable, light to one side, heavy to the other, is this the head bearings ?
thanks
just to add, could the steering be because the rim has "a flat spot" ?
Efes123
PostPosted: 17:49 - 17 May 2013    Post subject: Re: cbf125 problem, head bearing?? Reply with quote
You should be able to feel something through the bars if the bearing are going. With the bike on the centre stand, turning the bars, do you feel any resistance, or hear any grinding? It's a fairly easy job to check them, just a single nut, although finding a spanner could be problematic Wink
Highly unlikely, unless the flat spot is a big one, and the tyre is bulging.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
LockyUK
PostPosted: 19:11 - 17 May 2013    Post subject: Reply with quote
the tyre is not bulging, the flat spot is a fair size (not massive but not small about 1 1/2 inches), i have the haynes manual so i will see what it says, i will test the steering on the stand in the morning and report back, thankyou for the advice
neil.
PostPosted: 22:19 - 17 May 2013    Post subject: Reply with quote
If you sit on the bike, hold down the front brake and push down hard on the handlebars to compress the forks, do you get a click then?
The last post was made 13 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 41.03 Kb
