Divvys got a wobble on
sidewinder
PostPosted: 17:08 - 19 May 2013    Post subject: Divvys got a wobble on Reply with quote
Hello all
I have a wobbly bar issues.When the bike is slowing or going slow if you take you hands of the bars the bars get a wobble on.When i put my hands back on it stops?.it's like a mini tank slapper but no where near as bad.Going at normal road speeds it is fine only when going slow.I have noticed sometimes when leaning over front slightly feels like it wants to tuck under.Tire pressures are good and no oil is seen on the forks.We did fit new seals a few weeks ago could these be fucked already.cheapo specials from e-bay..
thank you for any help
Alpha-9
PostPosted: 17:20 - 19 May 2013    Post subject: Reply with quote
Mine does the same Razz
Fzr-600 1999
moonzoomer
PostPosted: 17:27 - 19 May 2013    Post subject: Reply with quote
Check the front wheel axle incase it is bent, front wheel bearings and the headstock bearings/cups for wear.
SQL
PostPosted: 17:29 - 19 May 2013    Post subject: Reply with quote
balancing
J.M.
PostPosted: 17:36 - 19 May 2013    Post subject: Reply with quote
Sure about the tyre pressures?
I've found if the XJ has the front tyre a few PSI too high then the front tucks in easily but feels like it wants to fall.
I also get the mini-tank slapper. It generally only appears if removing hands at 5.5k RPM. 5k or 6k is fine, strange.
2004 R1 & 2018 XSR900
sidewinder
PostPosted: 17:57 - 19 May 2013    Post subject: Reply with quote
Just checked my revs pretty much the same. Question tire pressures i run at front 34psi rear 36psi...
sidewinder
PostPosted: 17:58 - 19 May 2013    Post subject: Reply with quote
Mmmm 3 divvys all do the same.Is this normal ?
Muscle Bike Rider
PostPosted: 18:09 - 19 May 2013    Post subject: Reply with quote
Should be either 32f 36r (handbook) or 36f 42r ( Bridgestone website). Always have a pressure difference of 4psi between front and back.
Previously Known As A5tra_G
Old Bikes :2010 Kawasaki ER6 F & 2000 Honda VTR Firestorm
Current Bike : XJR1300
sidewinder
PostPosted: 19:01 - 19 May 2013    Post subject: Reply with quote
Vincent wrote:
Rear end problems can cause front wheel wobble too - check wheel allignment, shock condition/setting and tyre.
It's only just had a mot any they said everything was spot on no play or nothing ? Will check what you mentioned though Thumbs Up
sidewinder
PostPosted: 17:43 - 20 May 2013    Post subject: Reply with quote
Have just checked everything and all is nice and tight.or free moving so I'm a little lost now Neutral
sidewinder
PostPosted: 18:14 - 21 May 2013    Post subject: Reply with quote
Vincent wrote:
Did you measure the length of the fork springs when you did the seals?
No.am I meant to?
Alpha-9
PostPosted: 19:13 - 21 May 2013    Post subject: Reply with quote
wobbly bars
oily airbox
shitty gears
diiiiverrrrsssioonnnn Exclamation
My err valves? Have gotten loud recently, since it fell into neutral giving it beans and I heard a loud like pressure escaping sound, it seems louder, all clicky, what i'd attribute to badly adjusted clearances on a CG, but obviously the engines completely different
Should I get on that sharpish?
Vat ist?
It's really loud from around 4k Sad
Fzr-600 1999
J.M.
PostPosted: 19:19 - 21 May 2013    Post subject: Reply with quote
Alpha
Verb
To destroy or damage a bulletproof or highly mechanically regarded piece of machinery: "He really did an alpha on that!".
Wink Laughing
Check valve clearances and do a compression test?
Alpha-9
PostPosted: 19:22 - 21 May 2013    Post subject: Reply with quote
J.M. wrote:
Alpha
Verb
Wink Laughing
No loss of power from what I can see
Will need to, dunno where to start, I assume rocker off...
I am amazing, all I try to do is rag the shit out of it up to 70 as fast as I can on a hot engine but the gears always fucks me over and derp neutral, and pushing down to one unless i'm practically stopped will wildly chew the gears together like BRRRRRRD the sound of two cogs spinning and rubbing against each other but not clicking in Mad
Not gangsta bro
Need haynes manual, got online but no good to me when i'm outside
Times like this I need an ipad fag
Done like 700 miles on it so far... Oil leak from airbox seems to have gone and have put fresh oil in not too long ago. on 18k atm and I imagine service interval is around now or 20k
Fzr-600 1999
sidewinder
PostPosted: 22:19 - 21 May 2013    Post subject: Reply with quote
So maybe a complete fork overhaul might work.new springs the works.. Middle Finger
PostPosted: 22:52 - 21 May 2013    Post subject: Reply with quote
Must be coz mine did it too. Mostly fixed by fitting a new rear tyre.
sidewinder
PostPosted: 19:09 - 22 May 2013    Post subject: Reply with quote
Interesting .not so long ago had some conti go's fitted.maybe then the pressures are different from the bt45's it had on before Thumbs Up
CaNsA
PostPosted: 19:31 - 22 May 2013    Post subject: Reply with quote
SQL wrote:
balancing
This
or
yokes on the piss.
Undo the top yoke nut, loosen the bottom yoke clamps, bounce down a good few times (not forward), tighten top yoke nut, tighten both lower clamps.
Teme and me have just had to do the same on my zxr as it was weaving.
but i'd deffo get the front wheel balanced again though.
sidewinder
PostPosted: 19:34 - 22 May 2013    Post subject: Reply with quote
Vincent wrote:
You sure the rear wheel is in straight? Don't always go by the measurements on the adjusters, get a ruler out and measure from the swingarm pivot to the axle.
Tyres are fairly new then?
According to the mot guy spot on will take your advice and measure the gaps just in case .tires have got about 500 mls on them Middle Finger
sidewinder
PostPosted: 19:35 - 22 May 2013    Post subject: Reply with quote
CaNsA wrote:
SQL wrote:
balancing
This
or
yokes on the piss.
Will give that a go buddy Thumbs Up Karma
CaNsA
PostPosted: 19:36 - 22 May 2013    Post subject: Reply with quote
This bloke does a decent video of how to straighten forks.
https://www.youtube.com/watch?v=vSunBRB6-r8
Very Happy
The last post was made 13 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 128.1 Kb
