Seized retaining pins & splitting calipers
Ripp3rCrust
PostPosted: 17:43 - 19 May 2013    Post subject: Seized retaining pins & splitting calipers Reply with quote
Finally got around to attempting to remove the seized retaining pins in my bandit calipers, the pins to which the pads attach have seized in their holes in one of the front calipers and both pins in the rear.
Previously I had tried to drill a hole to the rear of the pin and tap them out with a drift, however this was unsuccessful.
As a result, I decided to split the calipers and get them out that way, the plus side of this being that I can also rebuild the pistons whilst I am at it.
However, as is tradition I seem to have encountered problems at every stage.
- Front brake caliper: Am I correct in thinking that these are unable to be split? As I cannot see any means to split them, and I cannot remove the pin so how can I remove the pin and pads and allow me to rebuild?
- Rear brake caliper: Here both pins are seized, I intended to crack open the bolts holding the caliper together slightly and then remove the caliper and subsequently open it up. The problem here however is that one of the bolts (highlighted red in the image) has rounded off. What are my options here in regards to removing this bolt?
Many thanks.
Current: '05 CBR600F - Previous: '01 GSF600S Bandit, '06 XR125
orac
PostPosted: 18:40 - 19 May 2013    Post subject: Reply with quote
you maybe able to use a bolt extractor, drill the the head and use a stud extractor, drill it right out and retap the thread with a helicoil.
or if you are having that much troubles (which it sounds like you are) get another caliper thats in better nick.
as for the front calipers, if they are the floating twin pot type, then no they can not be split
Ripp3rCrust
PostPosted: 21:15 - 19 May 2013    Post subject: Reply with quote
Thanks for the reply.
Yeah, the front ones are the floating type, any suggestions on how to remove the pin here?
New/salvaged calipers aren't an option for me, unfortunately, due to cost. Do you reckon an impact driver may work? Would prefer not to tap and helicoil if at all possible.
PostPosted: 21:22 - 19 May 2013    Post subject: Reply with quote
I have a pair of Mk2 front calipers. You can have them for the cost of postage, I was going to sling them in the bin. I'll make sure the bolts and pins are all free before I send them.
This is where you drill the holes to knock the pins out.
orac
PostPosted: 21:24 - 19 May 2013    Post subject: Reply with quote
if its rounded then no the impact wrench will have the same effected as hand tools.
second hand rear caliper is ony about £40. as for the front pins if it the same as the GS5 one then there should be an r-clip that needs to be removd first. the r-clip is on the inside behind the flang on the wheel side of the caliper. the oins should then be withdrawn towards the wheel side of the caliper.
if you have the r-clip out and it doesnt want to move try using a good quality set of mole or vice grips to rotate the pins an wiggle them out slowly - the most important thing is not to rush - thats when things get broken
Ripp3rCrust
PostPosted: 07:22 - 20 May 2013    Post subject: Reply with quote
Wow, yes that would be amazing if you wouldn't mind! Would save me a lot of headache.
Yeah, I had the R-Clip out and tried to rotate the pin with a pair of Vise-Grips. However, it only seemed to chew the sides of the pin up.
Reckon I will use some more 3in1 and see if I can free it up at all.
Damn corrosion!
The last post was made 13 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 54.83 Kb
