Piston size - Urgent Advice Appreciated!
NSR125-Kid-UK
Attention Whore
PostPosted: 23:29 - 29 Nov 2004    Post subject: Piston size - Urgent Advice Appreciated! Reply with quote
Well folks,I've finally talked myself into going and getting a rebuild as well as a load of other work done to the NSR. Problem is, while looking at prices for parts, the dude in the parts department noticed there were 5 piston sizes, to compensate for the wear on the barrel.
I don't know the size of my piston, and neither do the mechanics. As far as I am aware however, the bike has never had a top end rebuild, and so the piston should be the one fitted at the factory, this requiring the fitting of a #2 piston.
To be sure, the chief mechanic wants to take off the fuel tank and airbox, and look at the engine tomorrow, to see if it says the size of piston that's been fitted anywhere.
I'd find it a huge help if anyone knows where to find any such identifying marks - maybe stamped on the barrel? or on the face of the piston itself?
Allhelp gratefully appreciated Very Happy !
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
Adam_P
PostPosted: 23:34 - 29 Nov 2004    Post subject: Reply with quote
Err, surely if he's a qualified and experienced mechanic he'd know what to get and fit? Is it a dealer or an independent? If it's the latter and he's asking you that sort of question, I'd consider taking it somewhere else. It wouldn't fill me with that much confidence.
Sorry, don't have any advice on the piston! Embarassed Laughing
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
sickpup
Old Timer
PostPosted: 23:36 - 29 Nov 2004    Post subject: Reply with quote
I like this mechanic. He should really strip the engine to see how much wear there is. I once had an RS250 on its original piston that had to go to 3rd oversize.
cagiva gezzer
PostPosted: 00:02 - 30 Nov 2004    Post subject: Reply with quote
The original "family" of the cylinder will be stamped on the cylinder somewhere. I think the cagiva one is under the cylinder, so you have to take it off anyway.
If they are going to do it properly, they should measure the clyinder diameter as specified by the manual. Normally 10-15 mm down from the top.
PostPosted: 01:28 - 30 Nov 2004    Post subject: Reply with quote
The sizes are not so much to account for wear, more to account for production inaccuracies.
You need to really find the size of the barrel / piston currently fitted (think it is on the underside of the NSR barrel as well), or better still measure it (VERY accuratly).
hugo-a-gogo
PostPosted: 01:34 - 30 Nov 2004    Post subject: Reply with quote
I'd have thought measuring the bore would be sensible
"There are some things nobody needs in this world, and a bright-red, hunch-back, warp-speed 900cc cafe racer is one of them - but I want one anyway, and on some days I actually believe I need one. That is why they are dangerous."
Hunter S Thompson
clicky 4 bikey
sickpup
Old Timer
PostPosted: 01:53 - 30 Nov 2004    Post subject: Reply with quote
Sorry should have said CB250RS.
Keith is right but I'll explain further. A lot of bikes have 3 different standard piston sizes due to tolerance then 2 oversizes.
I would take the top off the engine to measure the bore and see how good or bad it is.
NSR125-Kid-UK
Attention Whore
PostPosted: 06:26 - 30 Nov 2004    Post subject: Reply with quote
Would this require a new gasket once the top's been off?
DM
PostPosted: 07:24 - 30 Nov 2004    Post subject: Reply with quote
Usually not, neither at the top of the cylinder nor the base. Runs fine afterwards.
Spiral
PostPosted: 08:23 - 30 Nov 2004    Post subject: Reply with quote
So true mate i stay away from independents unless i know the mechanic, i've heard some bad storys about services that were nothing more than a change of oil and a spark plug.
Theres one not to far from me that replaced a battery for somebody during a service, only they forgot to charge it up Laughing
****NORTHERN IRELAND NEWSFLASH!!**** According to a recent survey, 94% of loyalists said the best sex they ever had was in the shower; the other 6% haven't been to jail yet.***
PostPosted: 12:16 - 30 Nov 2004    Post subject: Reply with quote
Yes it would. You might get away without replacing the base gasket but it is not worth the risk.
Also to take the barrel apart either far enough to check for a size on the bottom, or to properly measure the bore size then you will be doing 99% of the work to replace the piston.
As to using local non franchised mechanics, I would not worry. If you read the Ride magazine surveys the official dealers are also often pretty awful.
mr jamez
PostPosted: 12:54 - 30 Nov 2004    Post subject: Reply with quote
There is a letter stamped on the bottom of the barrel, then you just need to get a piston with the same letter (A B C D or E). Not a very good idea to re-use a head gasket, so just replace any gaskets that you have to remove. Remember to check the barrel for damage, A new barrel with a OE piston is £85 from david silver spares.
They should be able to tell you what piston you need from the engine number anyway.
NSR125-Kid-UK
Attention Whore
PostPosted: 19:12 - 30 Nov 2004    Post subject: Reply with quote
Well, after much encouraging from BCF dudes, my bike is finally booked in next saturday to have the piston, rings, small end bearing and gaskets replaced.
Also, the dude said he's going to de coke the barrel, the exhaust, generally sort out the exhaust port, bleed my brakes, and sort out my slightly-slack throttle.
The total cost is £230, unfortunatley while I was chatting to a cool dude about the problem with my sliders, the mechanic (who is an acquaintance of mine) comes upstairs, hands me the keys and says with a grin "your steering head bearings are knackered" After I murmered "oh good Confused " He says "I am the bearer of good news" Laughing .
Ah well, that's something else to sort out, but at least the bike's no longer a worry Smile. Well it won't be, a week on saturday.
The last post was made 21 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 81.62 Kb
