brake pads moving
Sid_The_Sloth
PostPosted: 00:45 - 20 May 2013    Post subject: brake pads moving Reply with quote
Bandit 600 front pads feel quite loose and as a result are knocking when hitting bumps but also tapping when the wheel turns due to a slightly warped disk (not enough of a warp to effect braking in any way though).
How do I stop the pads from moving? Also feels like there a bit of excess play in the caliper too, both mounting bolts are solid but seems to be coming from the slide? Is this gonna eventually cos problems?
temeluchus
PostPosted: 02:17 - 20 May 2013    Post subject: Reply with quote
sounds like it could be a shagged wheel bearing.
Sid_The_Sloth
PostPosted: 20:46 - 20 May 2013    Post subject: Reply with quote
Had the pads out to replace them. Everything seemed fine before that.
The last post was made 13 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 38.81 Kb
