Tyre maximum weight - am I exceeding it?
c_dug
PostPosted: 08:57 - 20 May 2013    Post subject: Tyre maximum weight - am I exceeding it? Reply with quote
I knew my bike was a lardy thing but it weighed in at 260kg give or take at the last MOT and that was with about 1/3 tank of fuel and no rider or luggage. I was checking my tyre pressures the other week and noticed the front says a maximum load of 250kg, I'm unsure if this is a total bike weight or should be split between the front and rear?
Anyway the bike alone appears to be over the limit and that's with nothing on it, I weigh 100kg in my pants so must be pushing 125kg with all my gear on. Add the OH on the back and full luggage (happens maybe twice a year) and a rough add up puts it over half a ton! So now I'm either doubling the maximum load of the tyre or sitting on the limit, and that's just sitting still. What happens when I need to emergency stop from cough-mph fully loaded? Surely that puts most of the half ton through a single tyre?
Am I worrying about nothing or should I find some tyres more suited to the bike next time? There are BT023's suited to heavier bikes (BT023GT or something) maybe these would be better?
Musketeer
PostPosted: 09:09 - 20 May 2013    Post subject: Reply with quote
I imagine it's like with cars and tyre load is per tyre, not the weight of the whole vehicle.
EDIT: But thinking about it.. if you do a wheelie, then all is on your rear tyre Wink
PostPosted: 09:11 - 20 May 2013    Post subject: Reply with quote
Wouldn't worry in all honesty.
MarkJ
PostPosted: 09:12 - 20 May 2013    Post subject: Reply with quote
I just found a link for cars that said the load rating is per tyre, but then I closed the tab and can't find it again Neutral I imagine bike tyres will be the same, so 500kg for you? Maybe more if the rear tyre has a higher rating.
Ah, found the link: https://www.tesco-tyres.com/help/load-rating
If you have a tyre with a Load Rating of "91" as specified by your vehicle handbook, this indicates a maximum weight per tyre of 615kg
For anyone interested, apparently the number after the rim size is the weight rating:
https://www.avon-tyres.co.uk/motorcycle/load-index-and-speed-rating-symbols
Turkish
PostPosted: 09:54 - 20 May 2013    Post subject: Reply with quote
100% certain it's load per tyre. Same with car tyres.
The load rating is there for a number of reasons, including side wall rigidity and heat build up due to rolling resistance; you aren't that much over the limit for a single tyre so unless you are regularly spending minutes at a time on the back wheel you're OK.
ZX-6R G2
CBR125R RW6
c_dug
PostPosted: 10:26 - 20 May 2013    Post subject: Reply with quote
So if I have the bike fully loaded and assume it is at 500kg should I be doing something with the tyre pressures to keep everything in check. Baring in mind when the bike is fully loaded up like this I am most likely doing big miles on motorways.
mpf1959
PostPosted: 10:47 - 20 May 2013    Post subject: Reply with quote
ive looked into this before being fairly ample meself, Laughing and the best thing to do is find the gvwr of your bike, its usually in the tyres section of the owners handbook.
my gsx for example has a max load capacity of 210kg, thats for everything, you plus any passenger / luggage ect. im 130kg and the bride is 60kg, so thats a lot of weight.
most bikes seem to have a max load of around 190-200kg. even my anf125 has a capacity of 170kg.
The last post was made 13 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 52.89 Kb
