Cranks, fires a couple of times but doesn't Catch
JackDG
PostPosted: 20:04 - 20 May 2013    Post subject: Cranks, fires a couple of times but doesn't Catch Reply with quote
1992 GPZ 500
As title says, also smoke comes out from exhaust on cranks.
It was running poorly yesterday (stalls when come off accelerator, would not pass 8k)
Turned out the petcock was not acting consistant and engine would run out of fuel. Turned out the PO had the carb vent connected to petcock and not vaccume line. Got that fixed up so the carbs are getting fuel consistently now.
Since buying the bike a few weeks ago I have;
Changned oil / filter
New Spark plugs
New air filter
cleaned the carbs
JackDG
PostPosted: 21:26 - 20 May 2013    Post subject: Re: Cranks, fires a couple of times but doesn't Catch Reply with quote
JackDG wrote:
1992 GPZ 500
New Spark plugs
New air filter
cleaned the carbs
Just checked the spart boot plugs with the screwdriver near frame and it a bright spark is clearly visible.
Loosing patience with this :S
First timer so any help appreciated!
bladerunner
PostPosted: 23:09 - 20 May 2013    Post subject: Reply with quote
Take a plug out and see if it's wet. If it is try drying it out with a gas ring or the such.must be hot enough to dry the plug out properly. If its dry then try a thimble full of fuel down the plug hole and refit. That should at least sort out if it's a fuelling problem and get it started for a few seconds. Failing that try new plugs time.
JackDG
PostPosted: 12:25 - 21 May 2013    Post subject: Reply with quote
Sparks look fine, running a little rich but thats the least of my problems just now.
Another forum suggested I manually prime the carbs with fuel but that had no effect, it still cranks with smoke and firing but never catching on.
Now though when I press the starter sometimes it doesnt crank, like its pushing against a resistance and I hear a hissing noise coming from somewhere at the bottom of the front end.
bladerunner
PostPosted: 18:50 - 21 May 2013    Post subject: Reply with quote
Sparks can look fine but break down under compression and fail if they die due to rich mixture. Take the plugs out and spin the motor over to make sure you ain't hydro locked it.....keep the sparky bits away from the plug holes when you do this!
The last post was made 13 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 45.2 Kb
