| gman3000 |
 gman3000 Derestricted Danger
 Posted: 22:02 - 29 Nov 2004 Post subject: Nsr 125, a couple of problems |
Hi,
I fitted some Oxford Hotgrips to my Nsr, which knock out the indicators, then in the process of working out why this was, flatten my battery. So I disconnected them!! Over the next few days I had a few problem.
Firstly the battery wouldn't hold any charge after the bike was taken on a run for a while, this problem cleared up over the next two days.
But now my bike is stalling on me, if i'm at a junction the revs will fall on and the engine will stop. Plus its seems to have lost it's poke i.e the power vale is less effective??
The clutch now seems not to be disengaging when the lever is pull, and when the lever is pull with the bike in gear, the rear wheel is not free but engaged. I can't remember if it ever been free when I've tried this before.
I,ve had the bike 5 months
Any Ideas Please??
Thanks |
| mr jamez |
 mr jamez World Chat Champion
| alains |
 alains World Chat Champion
| mchaggis |
 mchaggis World Chat Champion
 Posted: 14:57 - 30 Nov 2004 Post subject: |
Stalling whilst idling and general poor running can also be attributed to mucky carburettors. Turning up the idle speed is a temporary fix at best. Removing the carburettor without damaging any rubber, taking it to pieces and blowing through the jets with compressed air to remove crap from them is the way to go.
You could do with fitting a in-line fuel filter if it is full of crap, these cost pennies apparently. (Thanks to Lonewolf or Stinkwheel for that one, I can't remember who exactly it was.)
As far as cleaning out the carburettor body, I just used kitchen roll and some white spirit. It worked though. (CG125). ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| ts50x0 |
 ts50x0 Spanner Monkey
| gman3000 |
| gman3000 |
| mr jamez |
| gman3000 |
| mr jamez |
 Posted: 20:58 - 01 Dec 2004 Post subject: |
It is an NSR125F, same as the NSR125R just unfaired  |
| Kickstart |
 Kickstart The Oracle
| gman3000 |
| mr jamez |
| gman3000 |
| mr jamez |
| gman3000 |
 Posted: 23:45 - 02 Dec 2004 Post subject: mr jamez |
Cheers have been taking it easy just..
You know anywhere I can get a workshop manual? |
| Ewok85 |
 Ewok85 Derestricted Danger
| gman3000 |
 Posted: 23:15 - 09 Dec 2004 Post subject: |
Hi,
Well I took the carb apart and it seemed ok, the bike is running okish at the mo, power still seem not right. the only other thing I noticed recently, that when you first start the bike then pull away the power seems to me better, but as you ride on reduces??
Any Ideas?
Thanks |
| Ewok85 |
| gman3000 |
| Mr Tickle |
 Mr Tickle Two Stroke Sniffer
| xenepp |
 xenepp Two Stroke Sniffer
 Posted: 23:58 - 03 Jan 2005 Post subject: |
This is a very interesting thread. My fiencee's fz600 does the same damn thing. We'll be running fine then after parking up for a while, getting back on the thing starting'll be a bit strained, then it'll just cut out at low revs and the battery'll be almost completely flat. After a recharge it'll be fine for a few days, then all of a sudden, the bugger will just die again.
It's lost power too, just like gman3000's bike, and when the revs drop and it cuts out, it's because the revs are hard to keep up.
I can only assume it's a short somewhere that flats the battery, and I would again, only assume, the engine will constantly need a spark when the revs drop thus the trouble with the performance drop. She's dropped it countless times (women) so I think she's bent the rear brake pedal in, thus the rear light stays on sometimes.
Feel free to shoot me if I'm wrong, just thought it might help others if it's right??
-Joel |
The last post was made 21 years, 268 days ago. Instead of replying here, would creating a new thread be more useful? |
