Storing a bike?
Joeval
PostPosted: 09:44 - 23 May 2013    Post subject: Storing a bike? Reply with quote
So, because of my work, I'm in and out quite a bit. At home for a week or two, maybe three, then off for a fortnight or so. Rinse and repeat...
So, when I bugger off to earn a spot of cash, my bike gets left sitting in a garage. As it is now, it's sitting on its stand, with the fuel off, and that's pretty much it.
Anything more I should do if I'm going to be leaving it unridden and unloved for a little while?
I do plan on getting a cover, just to keep the dust off. Should I get anything/do anything about the battery?
Cheers BCF!
CBT Passed 22/04/13
J.M.
PostPosted: 09:53 - 23 May 2013    Post subject: Reply with quote
Possibly consider getting a trickle charger for the battery, but that's about it really.
2004 R1 & 2018 XSR900
Rncv
PostPosted: 09:58 - 23 May 2013    Post subject: Reply with quote
Depends on how regular it is.
If its away for 4 weeks home for 1-2 then yes an optimate is a good idea.
If it's month on month of rotation then what you are doing is fine.
on the other hand, if you do say 8-12 weeks away at once then you will need an optimate or to charge your battery when you get back.
Normally I can get away without charging mine, just done 8 weeks and it struggled and I had to charge it.
Do you have a gel battery? helps a lot over acid.
One other thing I always do is to fill the tank, stop any rusting at all. I know It takes a long time but if you forget once then in my case it could be 3-4 months between refills... Thumbs Up
Current: 01' Bandit 600, 92' Goose 350
Previous: Lots!
anthony_r6
PostPosted: 10:01 - 23 May 2013    Post subject: Reply with quote
Leaving the bike sitting for two weeks shouldn't really cause too much of an issue with it. I'd remove the battery in cold weather, but that's about it.
Blunet600
PostPosted: 19:07 - 23 May 2013    Post subject: Reply with quote
Ive got my R6 in my garage which i will be taking off the road for probably at least a year. What do people recommend for storing a bike for this length of time? Its got near empty petrol in it which i heard is good if storing...?
cheers
Honda - Power of Dreams - NSR 125R - Hornet 600
Turkish
PostPosted: 19:28 - 23 May 2013    Post subject: Reply with quote
(To both) you want to brim the tank if storing. If it's two weeks at a time that should be OK on its own. If longer then might want to add a fuel stabiliser.
Either way the tank (shouldn't) rust if full and you can always dump the fuel if it goes bad.
If storing for a year, I'd probably put a generous squirt of oil in each piston barrel and refit the plugs. Coat the bike in acf50. When getting out of storage, turn over the bike a few times sans plugs to displace. Dump oil, filter (and possibly) coolant before riding. Good idea to change the brake fluid too.
ZX-6R G2
CBR125R RW6
Benson_JV
PostPosted: 20:09 - 23 May 2013    Post subject: Reply with quote
I did nothing for a year. Charged battery, started first time.
The last post was made 13 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 52.14 Kb
