servicing rockshox recon 351
Bike Chat Forums Index -> The Cycling Forum
steven_191
PostPosted: 16:35 - 23 May 2013    Post subject: servicing rockshox recon 351 Reply with quote
I have the u-trun motion control model with adjustable height.
I want to do a service on them and replace the oils and seals. Ive not dont a service on forks before so wanted to check if there was anything worth knowing before I do?
Im more than capable of doing the work but if there any advice then that will be helpful. I dont think these have ever been done before so dont know if I will need new bushes or anything but I wasnt going to order them (unless theyre cheap) in which case I might as well.
Any special tools needed or is it just allen keys and pliers etc?
cheers
steven_191
PostPosted: 16:38 - 23 May 2013    Post subject: Reply with quote
also a good place to actually get the parts. and manufacturers to go for or avoid?
I was going to ask the local bike shop to get me the stuff
pikey666
PostPosted: 21:44 - 24 May 2013    Post subject: Reply with quote
32mm rockshox forks are super easy to work on.
correct weight fluids are far cheaper if you buy motorbike ones, we use silkolene at work.
most of the time the oil seals are fine, same goes for the motion control cart. if you do need oil seal there isnt much price difference between oe and aftermarket. tf tuned are good guys to deal with.
https://www.tftunedshox.com/Catalogue/Shop-RockShox/RockShox/RockShox-Recon-Parts
although you can find them a few quid cheaper on fleabay.
9 times out of 10 all the fork needs is the lowers pulled, the insides cleaned and then rebuild with fresh fluids.
give yourself some time and clean workspace and you will be golden
steven_191
PostPosted: 11:01 - 28 May 2013    Post subject: Reply with quote
Cool cheers for that.
I plan on stripping and cleaning and replacing the fluids and to fit new seals while I'm at it.
The last post was made 13 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 39.85 Kb
