psu problems, tell me what connector i need
colin1
Captain Safety
PostPosted: 16:50 - 23 May 2013    Post subject: psu problems, tell me what connector i need Reply with quote
I have a PC that was new in 2009.
I recently upgraded the graphics card, and needed to fit a newer psu to get it to work.
Occasionally the PC would crash, which I took to be the psu being overloaded so I turned settings to a level that kept it from crashing.
Then a month or so later after a quilt may have been covering the vent on the psu, it died for good.
I've bought a better psu, but it doesnt come with the right connectors, so I'm wondering if you lot know what the leads are called and what to look up on ebay. The last psu I bought did say it didnt come with any accessories that may have been supplied with the original.
The connector missing is one that goes to the mother board, it's what i'd call 2 x 2, in that there are four plugs 2 side by side.
The recent psu is a corsair cx750
Scotsman37
PostPosted: 17:09 - 23 May 2013    Post subject: Reply with quote
What make & model is the motherboard?
PostPosted: 17:15 - 23 May 2013    Post subject: Reply with quote
It's just an auxiliary power supply. Two yellow & two blacks isn't it?
Cut the old one off and solder it into the molex 4-way hard drive loom. Yellow is 12v and black is 0v.
colin1
Captain Safety
PostPosted: 17:18 - 23 May 2013    Post subject: Reply with quote
manufacturer medionpc
model ms-7501 3.1
chipset amd 780g
southbridge amd sb700
colin1
Captain Safety
PostPosted: 17:21 - 23 May 2013    Post subject: Reply with quote
yes two black and two yellow.
I dont trust my soldering and bodging skills.
I want a connector that someone else has made.
what would such a connector be called on ebay ?
something like this
https://www.ebay.co.uk/itm/IDE-Molex-to-SATA-Power-Supply-L-Plug-Cable-Adapter-/180608062987?pt=UK_Computing_CablesConnectors_RL&hash=item2a0d14560b
or this
https://www.ebay.co.uk/itm/6-inch-Dual-Molex-LP4-to-PCI-Express-8-Pin-Auxiliary-Power-Adapter-Cable-PC-052-/280863082870?pt=US_Power_Cables_Connectors&hash=item4164be8976
but those dont have the 2x2 that i need
EDIT
could this be what I need ?
https://www.ebay.co.uk/itm/Standard-Molex-to-4-8-pin-Adapter-/221216353693?pt=UK_Computing_Drive_Cables_Adapters&hash=item338185ad9d
colin1
Captain Safety
PostPosted: 17:31 - 23 May 2013    Post subject: Reply with quote
bugger, just seen this which is definitely what I need,
https://www.ebay.co.uk/itm/Molex-to-P4-ATX-Power-Adaptor-Cable-Lead-for-PicoPSU-/230374315655?pt=UK_Computing_CablesConnectors_RL&hash=item35a3611687
is that the same as the one in the post above, below the word edit ? as i ordered that one first
Scotsman37
PostPosted: 19:46 - 23 May 2013    Post subject: Reply with quote
Here you go 8 pin to 4+4 pin which will allow you to use one of them for your mobo
https://www.ebay.co.uk/itm/Single-Braid-8-Pin-EPS-to-P4-4-4-Cable-Blue-/310671734990?pt=UK_Computing_CablesConnectors_RL&hash=item48557a78ce
Another one that will match the black if you want?
https://www.ebay.co.uk/itm/ATX-12V-PSU-8-Pin-to-8-4-4-Pin-Black-Sleeve-Extension-Cable-30cm-/300646938191?pt=UK_Computing_CablesConnectors_RL&hash=item45fff4364f
colin1
Captain Safety
PostPosted: 20:40 - 23 May 2013    Post subject: Reply with quote
thanks after petes mention of molex, i found two by looking at all the molex connectors on ebay, one that will definitely do the job only problem is I saw the other one first, and dont know if the one i ordered is as good as the other one
see what you think
i know this is what i need
but i ordered this one first
is it the same thing ?
The last post was made 13 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.51 - MySQL Queries: 13 - Page Size: 57.03 Kb
