Speedo and odomoter
locksmith-reece
PostPosted: 15:06 - 23 May 2013    Post subject: Speedo and odomoter Reply with quote
hello my speedo or odomoter dose not work as of my revs dont work either i belive its the speedo cable but i have my mot tommrow and ive just brought this bike its a lifan lf 125-30 dose it need to be working for mot to pass also i have a rear break but it is not that much use will this make it fail ? thanks
im a locksmith and a motorbike man i suppose that makes me the 2 wheeled lock picker !
Scotsman37
PostPosted: 16:42 - 23 May 2013    Post subject: Reply with quote
The Speedo/Odometer problem failure requires the speedo cable to be replaced, but the Rev counter will be an electrical problem either down to corrosion in the connector block of the wiring loom or possible at reg/rec end of it where it connects, but you could have a faulty rev counter needing replaced? So disconnect connections and spray with WD40 to drive out moisture/crap shortening it.
You could go to MOT except I am not sure if you could be failed on the that or it will be an advisory note depending how serious the fail will be or get through by the skin of it's teeth!
Thelostone
PostPosted: 17:26 - 23 May 2013    Post subject: Reply with quote
The speedo is not tested (or required) for the MOT, but is a legal requirement for road use.
Clicky for VOSA MOT guide.
locksmith-reece
PostPosted: 08:26 - 24 May 2013    Post subject: Reply with quote
thanks i was worrying Sad i just hope the bent clutch and shitty back brake passes !
Scotsman37
PostPosted: 10:44 - 24 May 2013    Post subject: Reply with quote
Rolling Eyes
locksmith-reece
PostPosted: 12:22 - 24 May 2013    Post subject: Reply with quote
it failed on a 2 list full Sad got to get rid of it now
Scotsman37
PostPosted: 14:25 - 24 May 2013    Post subject: Reply with quote
List the faults to give you some advice if cheaply fixable or not?
The last post was made 12 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 50.29 Kb
