| Nandonian |
 Nandonian Nitrous Nuisance
| hondakawasaki |
 hondakawasaki Nova Slayer
 Posted: 22:24 - 23 May 2013 Post subject: |
hi
sounds like your clutch is slipping, does the bike scream for a few seconds before the clutch finally grips
my mates ybr has the same problem
get some new friction plates and springs and it will be sorted shouldn't cost no more than £30 |
| Nandonian |
 Posted: 22:44 - 23 May 2013 Post subject: |
| hondakawasaki wrote: | hi
Thats what I've been thinking. Noticed also today that even with the clutched fully disengaged the back wheel still spins when in gear. Is this another sign of a worn clutch? Is there any way of adjusting it to stop it from slipping or is it just new parts? ____________________ Suzuki Katana AY50; Peugeot Jetforce C-Tech 05+06; Honda CG125 ; Yamaha YBR125; Aprilia RS125 FP; Lexmoto XTRS 125; Aprilia RS125 Race Replica; Aprilia RS125 Extrema FP; Seat Ibiza FR 1.9 TDI |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 23:03 - 23 May 2013 Post subject: |
The wheel will rotate with the clutch pulled in and the bike in gear just because of the movement of oil. You can easily check if you actually have sticking plates.
From cold. Leave engine off, clutch in, select 2nd gear, either try to rotate the rear wheel by hand or move the bike forwards with you on it. If you can move it freely and easily, not likely sticking plates.
If there is an initial small drag, then a click and then easy movement forward. Yes you have sticking plates, and you just unstuck them
Although they will likely stick again next time you stop and the bike cools.
You can also try to stop the rear wheel rotating with your boot when the engine is on and the clutch is in. If it's just natural momentum, you'll easily be able to stop the wheel. If its sticking clutch plates, it will nearly take your foot off
Which is why the first method is probably better. |
| Nandonian |
| Pigeon |
| Nandonian |
| Pigeon |
| Nandonian |
 Posted: 15:29 - 25 May 2013 Post subject: |
I've adjusted the clutch lever and now the clutch isn't slipping, but now it has a ridiculous amount of play - enough for me to accidentally stall because it wouldn't engage at the lights
https://www.youtube.com/watch?v=77SkrICRpGk&feature=youtube_gdata_player
How can I adjust it? ____________________ Suzuki Katana AY50; Peugeot Jetforce C-Tech 05+06; Honda CG125 ; Yamaha YBR125; Aprilia RS125 FP; Lexmoto XTRS 125; Aprilia RS125 Race Replica; Aprilia RS125 Extrema FP; Seat Ibiza FR 1.9 TDI |
| Mark65 |
 Mark65 World Chat Champion
 Posted: 16:40 - 25 May 2013 Post subject: |
Odd, when I changed my cable I just set everything at halfway then connected it up, only needed a tweak to get the play.
Is the clutch arm on the casing sticking?, pull it right back and mark it and the casing then connect it up and set cable, pull lever and see if marks line up again when you release the lever, it should go back.
What about the clutch cable is it sticking in the outer sleeve?(frayed maybe inside).
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| ian505050 |
 ian505050 Traffic Copper
The last post was made 12 years, 249 days ago. Instead of replying here, would creating a new thread be more useful? |
