Help for LTD 750 1982
Ralm
PostPosted: 14:14 - 24 May 2013    Post subject: Help for LTD 750 1982 Reply with quote
Hei
Theres no sign of life when i turn key on.
I was riding, stopped and when i hit START button bike just died.
Checked battery and ignition. Its ok.
What can be the problem anyone?
Aff
PostPosted: 14:16 - 24 May 2013    Post subject: Re: Help for LTD 750 1982 Reply with quote
Checked them how?
Do you have no dash lights or anything?
Have you checked all your fuses? (including main 30A fuse).
Electric Bike Project
Timmeh
PostPosted: 14:21 - 24 May 2013    Post subject: Reply with quote
Bikes dies then nothing works. Hmm, a tough one. Thinking
Have you even considered checking the voltage across the battery before you start pulling things apart?
Ralm
PostPosted: 14:28 - 24 May 2013    Post subject: Reply with quote
I did checked battery and the voltage is ok. However where the hell are fuses on this bike? Dont even find it in service manual book.
Ralm
PostPosted: 14:30 - 24 May 2013    Post subject: Reply with quote
No, no dash lights or anything.
Aff
PostPosted: 14:31 - 24 May 2013    Post subject: Reply with quote
Most likely the main fuse then, sorry don't know the bike so cant help with location.
:edit: according to the interwebs its under the left side cover.
Timmeh
PostPosted: 14:40 - 24 May 2013    Post subject: Reply with quote
trace the positive wire from the battery, it should lead you to the main fuse or fusebox.
Ralm
PostPosted: 15:29 - 24 May 2013    Post subject: Reply with quote
Yup its broken 10A
Aff
PostPosted: 15:36 - 24 May 2013    Post subject: Reply with quote
Ralm wrote:
Yup its broken 10A
Think it should be at least a 20A.
Ralm
PostPosted: 16:53 - 24 May 2013    Post subject: Reply with quote
I did traced one wire from the positive and found a box with 2 fuses. Howevere theres two plugins disconected from this wire. Is that it??
Replaced it but still nothing.
Second one wire whice goes from positive dont know where it ends.
doggone
PostPosted: 19:06 - 24 May 2013    Post subject: Reply with quote
When *nothing* works it's sensible to rule out poor earth connection first.
Easy way is jump lead onto neg terminal and some bright metal part - any sign of life or clicking?
If no jump leads, you could use any old bit of wire to get an idea - with the jump lead it would probably even start.
Ralm
PostPosted: 19:17 - 24 May 2013    Post subject: Reply with quote
Here..
The second one is earth but where to lnk this wire... Sorry i suck at EL stuff.
Ralm
PostPosted: 11:59 - 25 May 2013    Post subject: Reply with quote
Found these burnmarks. Can these couse this problem?
Its bronse colour. Should i replace this?
krytenboog
PostPosted: 14:20 - 25 May 2013    Post subject: Reply with quote
Daft I know but have you checked the kill switch?
trevor saxe-coburg-gotha
PostPosted: 17:47 - 25 May 2013    Post subject: Reply with quote
Man. That would both suck and rule to an almost insane degree.
PostPosted: 17:48 - 25 May 2013    Post subject: Reply with quote
Wait - did they even *have* kill switches then? This '87 bike of mine hasn't.
Ralm
PostPosted: 18:44 - 25 May 2013    Post subject: Reply with quote
FIXED!! Thank u all.
Aff
PostPosted: 18:50 - 25 May 2013    Post subject: Reply with quote
Don't tease, what was it?
Ralm
PostPosted: 21:59 - 25 May 2013    Post subject: Reply with quote
I found wires in headlight wet and in contact. After i put some isolation everything did fine.
PostPosted: 11:40 - 29 May 2013    Post subject: Reply with quote
Nice one dude. Thumbs Up
R1stu
Shrek!
PostPosted: 16:21 - 29 May 2013    Post subject: Reply with quote
Sometimes its simple as that! Ive not had my ninja running now for over 2 weeks. Spent £60 in parts still nothing. Only to notice that the clutch switch had broke and the wire had fallen out! plugged it back in, and low and behold. Bike starts! Embarassed
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
The last post was made 12 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 106.04 Kb
