| -Matt- |
 -Matt- World Chat Champion
 Posted: 16:55 - 24 May 2013 Post subject: Caliper piston getting nackered |
Hi all
Just did my first ever brake service/clean at home - took me a mammoth 5 hours total hopefully be a bit quicker next time round ...
I noticed one of my pistons on the front right caliper is a bit stiff [had to hold the others to get it to come out and then it was a bit slow and doesn't quite go back in as far as the others].
This is causing [as has been the case for a few months] very slight rubbing sound when the wheel is turned were i think the pad isn't quite going back as far as it should.
Is this something i particularly urgently need to get sorted or as the pad wasn't noticably worn more than the others and the wheel still turns fine etc could i leave it a few months without any problems.
Just spent the last 2 weeks servicing everything don't really fancy servicing the caliper too just yet if i can avoid it
Cheers all |
 ..... Quote Me Happy
| -Matt- |
| mentalboy |
 mentalboy World Chat Champion
| Islander |
 Islander World Chat Champion
 Posted: 22:50 - 24 May 2013 Post subject: |
You'll have reduced braking efficiency too. Time for a rebuild - new seals, clean the crap out of the seal grooves, clean the piston up, a touch of red rubber grease, reassemble and bleed.  |
| -Matt- |
 Posted: 03:26 - 25 May 2013 Post subject: |
Guess id better crack on with it then ..
Is it fairly straight forward if you know how to bleed/change pads already, just slotting in new seals relube piston and push it back in?
To get the piston out you just literally pump it over a bucket til it and the fluid comes out i presume ?
Leaving the other set of pads in shouldnt matter should it also, hate trying to get the damned pad pin through takes me ages
Cheers guys |
| mentalboy |
The last post was made 12 years, 215 days ago. Instead of replying here, would creating a new thread be more useful? |
