another oil sump threaded thread
DrSnoosnoo
PostPosted: 21:59 - 25 May 2013    Post subject: another oil sump threaded thread Reply with quote
Yep, I threaded it I think. Now ive used the search the function so my question is regarding the repair:
Do I do the helicoil idea providing I've only got access to a basic drill and limitted bits OR just try to screw in a slightly larger thread to use an oversize bolt for the future?
It's these or I try get it to an engineering place and pay them, FSM knows how much that will be though.
Can I have your advice please BCF?
Islander
PostPosted: 23:41 - 25 May 2013    Post subject: Reply with quote
Get it helicoiled.
ian505050
PostPosted: 00:00 - 26 May 2013    Post subject: Reply with quote
drain oil, remove sump plate, drill new hole, tap new hole, put new sump bolt in hole, make sure you use copper washer.
or..
Replace sump plate with a new sump plate off a bike that is being broken on ebay.
kestrel
PostPosted: 11:14 - 26 May 2013    Post subject: Reply with quote
On aluminium sumps with damaged threads I usually remove the threaded hole with a holesaw then weld in a new threaded boss and fit a new sump plug.
Threaded aluminium bosses and plugs are available from many motorsport suppliers and it shouldn't cost any more than about £10-15 to have it TIG welded in. We've done a few of them at work and usually charge a tenner for the tea kitty.
There are other methods of repairing sump plug holes but this is the one I prefer as it's a permanent good as new repair.
Isle of Man.........Road Racing Capital Of The World
DrSnoosnoo
PostPosted: 11:17 - 26 May 2013    Post subject: Reply with quote
Been ringing around and im gonna get a new sump.
As for the comment of how do people do this?
My answer is just, not all of us have worked with mechanics for years, in my case ive only been fiddling for a year and not had to do this before. I very much believe in the idea of learn from your mistakes which I have so I wont make the mistake again. I know it was a silly mistake and I knew I had to be careful.
When cracking the sump plug off to drain, I had to give it some force then when putting the plug back in I gave nowhere near the force it took to get off, it just went. Thats as much as I know.
I'll be much more careful in future because I dont fancy changing the sump everytime
Islander
PostPosted: 11:46 - 26 May 2013    Post subject: Reply with quote
Buy a torque wrench. It'll teach you how much pressure to apply to a bolt/nut.
Turkish
PostPosted: 11:54 - 26 May 2013    Post subject: Reply with quote
It's possible it was cross threaded, either when you put it back in, or when the last person put it back in.
Tip for the future; on a fastener with clean (and/or lubricated) threads, it should be possible to get said fastener most of the way home with fingers only. if it tightens up in the few couple of turns suspect the fastener is cross threaded. This is especially important with spark plugs.
Good luck!
ZX-6R G2
CBR125R RW6
Timmeh
PostPosted: 12:00 - 26 May 2013    Post subject: Reply with quote
IMHO the far biggest cause of people stripping the threads (bar basic stupidity) is because they re-use the copper crush washer.
The last post was made 12 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 60.82 Kb
